About to order some stuff and wanted to know...
I have asked before but I want to be certain this is the right radiator.
http://store.summitracing.com/partde...5&autoview=sku
Are the inlet and outlet hose flanges the right size? (1 1/2")
I also plan on tapping the oil pan and wanted to know if you guys are running a straight bulkhead or not.
I know you cant have mor than a 30* angle on the drain hose leaving the turbo so I guess you guys with the turbos mounted closed to where the battery used to be are tapping the front passengers side right?
This is a nicer radiator at a lot lower price. The griffin uses epoxy to mount the cores to the tanks and these are 100% welded.
http://www.competitionmotorsportsonl...stem-GM/Detail
