2001 f-body O2 sensor
I was searching for O2 sensor for my friends 2001 Camaro LS1 I came up with this and I dont know which one the camaro has he got the "Service engine soon" he toke it to the dealer and when they scanned it they told him you need to replace the O2 sensors and now we will order sensors for him but we dont know which one the f-body has
http://www.jegs.com/i/Denso/313/234-...902542%7C11523
if anyone knows please give me a link of how the connector of the O2 sensors looks or just give me direct link for the sensors Im stuck here
This is the rear http://www.jegs.com/i/Denso/313/234-4000/10002/-1
I'm just crossing numbers from the autozone catalog to jegs. Same brand, same numbers.
Jegs is almost $20 cheaper per front sensor (compared to autozone) they are around $5 more per sensor for the rear sensors.
Any peticular reason you are going with that brand?
The reason why we will order these sensors because they are cheaper than the original ones from our dealer for the front sensors it cost 120$ each! thats why we will order these sensors
What codes are in memory. The codes will tell you which sensor is the problem. Bank 1 Sensor 1(B1S1) is the right bank(passenger) upstream(before the cat). Bank 1 Sensor 2(B1S2) is downstream(after cat). Bank 2 is the left bank(drivers side), B2S1 and B2S2. Just look at the code description and it will tell you the affected circuit and which sensor it is. If your friend did not get the code numbers from the dealer and his MIL is still on, just go to an Advance, Auto Zone or O'Rielly and they should be able to hook up a code scanner and tell him. HTH.
Mickey
Mickey
