Steering Column HELP!! CHEVY II aftermarket front
I have a 63 chevy II with the checkered racing front end. I install an ls1 and t56... Now I order the flamning river column with tilt etc... FLA-FR20005 from summit racing... I have 2 universal joints that came with the checkered kit and I need to know what brackets I need to secure this properly... I know a couple of people have used this steering column with the aftermarket front clips but I can't find the posts...
btw the joints I have are 3/4 X3/4" smooth and the other is 3/4 X 9/16spline, but coming out of the steering column its 1"DD ???
Thanks Mark Tisdale
Thanks Mark Tisdale
Steering Coulmn Help
HI MAN I HAVE A 66 CHEVY 2 WITH THAT SAME FRONT END AND I USED AN IDIDOT COLUMN AND FLAMING RIVER JOINTS AND STAINLESS SHAFT. MY COLUMN HAD A 1"DD SHAFT AND I JUST GOT A 1"DD TO 3/4"DD JOINT AND USED 3/4"DD STAINLESS SHAFT. I DIDNT USE THE CHEAP JOINTS THEY SEND WITH THE FORNT END. INSTEAD I BOUGHT THE GOOD FLAMING RIVER STAINLESS JOINTS. I WAS TOLD THAT THOSE CHEAP JOINTS WOULD BIND UP WHEN YOUR CAR WAS TURNING TIGHT.
Dude your engine bay is clean my man and not over done!! Yea the flamning river and ididit are basically the same... what brackets do you use to mount the column.. any part numbers.
I Built A Bracket For The Lower Column Mount. Then Once I Got That In Place I Measured From Joint To Joint And Then Cut The Shaft To Lenth. I Didnt Write Down Any Part#s For The Joints. Sorry Hope That Info Helps
