Tools & Fabrication - Completed the carhauler
BADD SS
05-24-2008, 07:01 PM
Figured I would post some pics of the completed Car hauler I built this winter. Its now on the road ready to go.
Total length 40' 6"
Deck 33'2"
Empty weight 4,180 lbs
GVWR 14,000
http://i191.photobucket.com/albums/z66/taketime2pawz/IMG_0529.jpg
http://i191.photobucket.com/albums/z66/taketime2pawz/IMG_0526.jpg
http://i191.photobucket.com/albums/z66/taketime2pawz/IMG_0527.jpg
http://i191.photobucket.com/albums/z66/taketime2pawz/IMG_0528.jpg
http://i191.photobucket.com/albums/z66/taketime2pawz/IMG_0532.jpg
http://i191.photobucket.com/albums/z66/taketime2pawz/IMG_0530.jpg
http://i191.photobucket.com/albums/z66/taketime2pawz/IMG_0534.jpg
http://i191.photobucket.com/albums/z66/taketime2pawz/IMG_0533.jpg
http://i191.photobucket.com/albums/z66/taketime2pawz/IMG_0535.jpg
And here is a pic of what it started as.....
http://img.villagephotos.com/p/2002-12/77230/QFHEV-100_1612.JPG
http://img.villagephotos.com/p/2002-12/77230/MWINF-100_1637.JPG
http://img.villagephotos.com/p/2002-12/77230/JTEQW-100_1711.JPG
jdustu
05-25-2008, 08:12 AM
Nice work man, That is impressive!
Did you wire weld the whole thing? Flux core?
sloganish
05-25-2008, 08:48 AM
thats sick!
Pinky93
05-25-2008, 08:50 AM
That is an awesome job!! Now, let's fill it up with cars!!!
BADD SS
05-25-2008, 12:10 PM
Thanks
Yeah, I Mig welded it with my Miller 252
Already hauled 2 cars this week.. :)
Drew04GTO
05-25-2008, 01:54 PM
Looks awsome. Was going to ask if you MIGed it or stick welded that but you aready answered that question. If you don't mind me asking, on those vertical beads did you weld them up hill or down hill? Not downplaying it or anything, just some constructive critisism. Nice trailer but I do a lot of structrual welding and have always been taught to NEVER go downhill, its not exactly desireable for penetration. Correct me if I'm wrong but the welds where your gussets meet your 5th wheel appear to be down hill.
BADD SS
05-25-2008, 02:53 PM
They are uphill. It actually was a little hairy as I did it on a windy day as well. (im on an island with no LWS) So without fluxcore, I had my friend hold some plywood they were coming out like shit. So I pulsed it going up a little at a time, between wind gusts.
I do structural stick welding too, but my bobcat was off Island so I miged it.
Down hill is a no no, except for sheetmetal imho.
Drew04GTO
05-25-2008, 05:32 PM
Cool, yeah. I realized they were uphill after getting on a better computer screen. I dig it, if you don't mind me asking about how much do you have in it?
BADD SS
05-25-2008, 06:06 PM
Just under 4 grand, but it's just how I wanted it, I saw some real cheaply made ones, for $5500 so I think I came out ahead...
One Bad Z
05-26-2008, 12:38 AM
gooseneck F T W!!!!!!!!!!
1QWIKBIRD
05-27-2008, 06:44 PM
That's nice work. Did you buy blue prints to work from, or just take some measurements and have at it? How about to spots mounted on up on the goose neck as work lights for loading and unloading, maybe even double as reverse lights?
BADD SS
05-27-2008, 07:53 PM
Thanks, I designed it myself. No blueprints. I made it just long enough for 2 f bodies, and wide enough for most vehicles.
I left several places to tap in for lights, as of right now, there isnt a need. I still have to get my Camaro back on the road first... :)
xfactor_pitbulls
05-30-2008, 11:07 PM
FWIW, all neck gussets by trailer fab. shops are welded out downhill with 70 series wire, they never break.
eschoendorff
05-31-2008, 09:10 AM
Nicely done!!!!
fastgmc98
06-04-2008, 06:11 PM
Good looking car hauler! I'm jealous!!!
Reject
06-06-2008, 10:57 AM
i have no idea what yall mean by uphill downhill and all that shit i just know its an awsome trailer!
romoranger
06-06-2008, 01:20 PM
that thing is awesome. makes me finally want to go out and build my own. MY size c-channel is that? 5" tall 1/4" thick?
BADD SS
06-06-2008, 02:50 PM
6" x 10.5 lb Which is .303" I think, a little under 3/8ths its fairly thick. Then there is a 3'' x 1/4 flat strip welded under that, tied into the 3"x 4.1 lb crossbraces, which are doubled up.
Randy_S
06-06-2008, 04:26 PM
Nice looking trailer! How did you determine where to position the axles? How balanced is it with two cars loaded and hooked up to your 1 ton? Does your truck sag a lot?
BADD SS
06-06-2008, 05:32 PM
I only have a 3/4 ton, but with airbags @55 psi, it barely sags at all, the truck is actually still nose down by alot.
As far as axle position, I looked at a friend of mines bumper pull 2 car, and moved them back about 3 ft for more pin weight. This trailer likes alot of pin weight, the more the better. It rides beautifully when it has about 2200 lbs on the pin, which is both cars as forward as possible.
anthony m
06-07-2008, 08:32 PM
Great job.How much money and time into that set up?
1QWIKBIRD
06-08-2008, 07:25 PM
How thick is the diamond plate for the runners?
binks0678
06-08-2008, 09:47 PM
wow nice job, very nice looking trailer
01ssreda4
06-09-2008, 06:39 PM
great looking trailer...in my welding profession downhill is a no no. but depending on joint design and strength needed, it could be exceptable.
BADD SS
06-11-2008, 08:04 PM
Just under 4 thousand roughly to build. About 1 month and a half, working on weekends only. Most of it was finishing work, it was framed up in two days.
The runners are 1/8" thick diamond plate.
Goober79
06-12-2008, 10:58 AM
Wow great work!
