Driveshaft Question
Driveshaft Question
Have a built 4l60e from Performabuilt, now going to either a 9" or 12 bolt, question is this as for the drive shaft is there going to be a lenght issue? does it need to be shortend or is the stock lenght correct? or what does the lenght jave to be?, I am sure there will be a Ujoint change for the rear. Thanx.
http://www.exoticperformanceplus.com....html?item=541
The 12 bolt uses the same length driveshaft as the oem 10 bolt does. The Mosr 9 inch needs a one inch longer driveshaft. Bob
