Pioneer AVIC-D3 Installed
Old 05-25-2008, 04:41 PM
Copy & Paste Moderator
VIP1's Avatar
Default Pioneer AVIC-D3 Installed
Here is my Pioneer AVIC-D3 installed.
Up Close
500 x 375
1280 x 960
2592 x 1944
Night - With Dash Lights
500 x 375
1280 x 960
2592 x 1944
Night - No Dash Lights
500 x 375
1280 x 960
2592 x 1944
Bluetooth Microphone Placement
(Lower right corner in front of gauge lens.)
500 x 375
1280 x 960
2592 x 1944
I wrapped 2 - 3" of the wire behind the microphone with a few layers of electrical tape to protect it from the edges of the gauge bezel.
Further away
500 x 375
1280 x 960
2592 x 1944
Bezel Removed
500 x 375
1280 x 960
2592 x 1944
I made my own mounting brackets using some spare steel I had lying around (the steel side panel from an old computer case). They are basically two large broad "L" brackets drilled/cut in the right places to mount them to the sides of the headunit and the headunit to the dash opening. I started out with the flat sides of a computer case, cut the rough amount I needed and bent it to shape. I think the measurements where: Height: height of the headuint, Depth: 4", Tab: 2". I then centered the headunit in the opening. There is a lip/bump-out about 3/16" back from the face and I lined that up flush with the HVAC panel. If you look at the pics, the tab of the brackets is slightly set back from that lip/bump-out. Then, I cut the brackets to fit (trimmed tab length and cut slots for the stock mounting screws and bezel mounting holes). With the brackets in place, I made note of how they aligned on the sides of the headunit. Then I removed the headunit and made a pattern using a piece of paper of the existing screw holes on the sides of the headunit. I used 4 screws on each side (8 screws total). The sides of the headunit already had screw holes because on some cars, it'll mount to the stock bracket that way. I transferred the pattern to the brackets and drilled the holes on the brackets to line up with the existing holes on the headunit. I attached the brackets to the sides of the headunit using the screws that came with the headunit.
Bezel Front
500 x 375
1280 x 960
2592 x 1944
Bezel Back
500 x 375
1280 x 960
2592 x 1944
I made my own trim bezel. I started out by trimming the plastic bezel that comes with the AVIC-D3 to the needed shape and used spray contact cement to attach a layer of 1/8" thick black "chip board" card board (under $3) over the resulting pieces of the trim (top-half/HVAC-sides/HVAC-bottom) . It is similar to notepad backer, but higher quality, better/smoother finish, and black. Actually, its more like photo mount. Architects (like my brother) use it often in model making. It is available at art supply stores. I also added some layers of the card board to the back in places to add depth so that it can't be pushed in too far when mounted. I was planning on wrapping it with some vinyl I had, but at another art supply store, I found some velour "paper" (under $2) and wrapped it with that instead. Its attached via double-sided "carpet-tape". I think it looks better and has a good feel. It looks and feels just like velour fabric, but its thinner and stiffer. I didn't use the contact cement because I didn't want to risk it seeping through. Total cost: roughly $30 ($23 of that is the spray glue... of which I used a tiny amount) Its attached via pressure fit with a little velcro at the bottom edge under the HVAC controls.
UPDATE: After a few months and some hot days, the shroud I made started to buckle and the middle and lower horizontal sections bulged out. I added a strip of steel behind each and will see how that does.
UPDATE: The added steel seems to have done the trick. Its still solid a few months later.
Dash Opening Trimmed
(WhiteBird00 took these 2 pictures, but I'm re-hosting them on my domain.)
The ribs at the top of the opening had to be trimmed about an 1/8". I used a coarse sanding drum on my rotary tool (Dremel knockoff) to trim the ribs at the top of the dash opening. My brother held a vacuum hose next to the work-in-progress to catch the flying plastic debris. WEAR GOGGLES WHEN DOING THIS TO PROTECT YOUR EYES!
The brace at the back of the tray also had to be removed (not pictured). I used a cutting disk on the rotary tool to cut the plastic of the vertical brace at the back of the tray and just bent back the metal backing of it. WEAR GOGGLES WHEN DOING THIS TO PROTECT YOUR EYES!
Wiring
The AVIC-D3 is connected to the stock wiring harness using a standard 21-pin 1988+ GM harness. The Scosche number is GM-02B. The Metra number is 70-1858.
The steering wheel controls are retained using a PAC (Pacific Accessory Corp) SWI-PS . It plugs into the remote port on the back of the AVIC-D3 (and other Pioneer headunits with a remore port).
The stock CD-Changer cable is no longer used. It is left disconnected.
[UPDATE -- 2009-05-10]
I bought the CDI200 IPOD cable from Amazon for $11 shipped and a 120GB IPOD Classic for $225+tax from Costco.
Here they are installed. The Cable connects to the back of the headunit and the IPOD is velcroed to the flat spot hidden by the right lip of the glove box. That lip doesn't touch the IPOD at all.
500 x 375
1280 x 960
2592 x 1944
500 x 375
1280 x 960
2592 x 1944
Old 05-25-2008, 06:36 PM
toslo5o's Avatar
very nice that looks great!
Old 05-25-2008, 06:43 PM
mycamaroSS's Avatar
looks good,m cant wait to get/install mine. But what material is that bezel, looks like it's wrapped.
Old 05-25-2008, 07:13 PM
Irocem99's Avatar
Vip that looks really good. Where did you get the Knight Rider screen ? I want that..I hope I can get that on my Kenwood 512. I drumeled the ribs out on the top. I had to cut the tray some..I can get the Kenwood in without cutting the re enforcement in the back..Now if C5 KIdd would get back to me so I can get the bezel..I don't have the patience or the time to make my own bezel..You did a good job..
Old 05-25-2008, 10:41 PM
VIP1's Avatar
Thanks for the compliments.
Its velour "paper" wrapped over a sandwich of plastic and cardboard. My first post in this thread has more detail. Let me know if anything doesn't make sense. I didn't take any work-in-progress pictures though.
Originally Posted by Irocem99
Where did you get the Knight Rider screen?
Its a composite of a picture of the real dash from the show and some cleanup work I did on the text and buttons using bits of other pictures I found online and some re-creation. The only thing left untouched is the actual red voice LED bars.
I want that..
Here you go...
Load/Splash Screen
Nav Menu
AV Menu
Old 05-25-2008, 11:00 PM
Irocem99's Avatar
Very nice..
Old 05-26-2008, 03:27 AM
2000Hawk's Avatar
That looks real cool man, the knight rider screen looks great. But im sure it looks even better at night.
-Joel
Old 05-26-2008, 07:29 AM
Richiec77's Avatar
Very clean install man. It's looks good in there.
Old 05-26-2008, 08:39 AM
VIP1's Avatar
Thanks. I forgot to take a night picture.... I'll try to take one tonight.
Old 05-26-2008, 09:36 AM
Ungrounded Moderator
WhiteBird00's Avatar
Nice job man! The bezel looks really good. I like that circuitboard background. Do you mind if I use it?
Old 05-26-2008, 01:20 PM
MonkeyBoneSS's Avatar
Who did you buy the D3 unit from? Pm me if you can't post it. Thanks
Old 05-26-2008, 11:45 PM
VIP1's Avatar
Thanks.
Sure you can use the pic.
WhiteBird00. He swapped out the AVIC-D3 for a Kenwood nav unit. It was a deal I couldn't pass up.
Old 05-26-2008, 11:49 PM
VIP1's Avatar
I added night pictures.
Old 05-26-2008, 11:53 PM
Irocem99's Avatar
What holds the bezel you made to the frame? Did you use the factory poles or velcro it on?
Old 05-27-2008, 12:03 AM
VIP1's Avatar
Its a pressure fit with two small pieces of velcro (you can seen them in the pics of the back of the bezel) to help secure the horizontal section under the HVAC controls.
Old 05-27-2008, 09:25 AM
VIP1's Avatar
Since I've been asked via PM, I added more detail about how I made the brackets.
Old 05-27-2008, 06:58 PM
VIP1's Avatar
I made a mistake in describing the mounting depth.
The face of the AVIC-D3 has a lip/bump-out about 3/16" from the front. That lip is what is flush with the HVAC panel. If you look at the pictures in the thread, you can see that the tab of the brackets I made is lined up with that lip.
Old 05-28-2008, 10:34 PM
WhiplashDVD's Avatar
Default Just got mine
I just picked up my d3. I cant wait to install it. I hope its worth the money it costs. So not to hijack your thread but have you or do you plan to try the PAC SWI-PS for steering wheel controls? Im thinking of getting one before i install the unit.
Old 05-29-2008, 02:11 AM
toslo5o's Avatar
hey where did you place the GPS antenna?
Old 05-29-2008, 08:17 AM
firebirdude's Avatar
Mine works great sitting in the corner of the dash.
And I'd think about having a pro make you a custom bezel.
Quick Reply: Pioneer AVIC-D3 Installed
