Any reason to avoid '04 GTO LS1?
Old 05-25-2008, 10:00 PM
AustinYukon's Avatar
Default Any reason to avoid '04 GTO LS1?
I might have a good deal on a 38K mile LS1 out of a GTO. The only 'problem' I am facing is the fact that I have to buy the motor/tranny and it's a T-56 setup. I am going to run an auto in my '56 Belair project.
I'm hoping I can buy the assembly and sell the T-56 and all related stuff then just buy a built Auto setup.
I'm assuming I can't use the 6sp harness and ECM though, either.
Any reason to avoid the '04 model year LS motors?
Dan
Old 05-25-2008, 10:26 PM
PewterMNZ's Avatar
check out ls1gto.com
probably find better answers sooner there
Old 05-25-2008, 10:33 PM
torquejunky's Avatar
I don't know a whole lot about late model GTOs but from one old school car guy to another I would keep the 6 speed. I had a turbo 400 in my 71 Z28, which was great for racing but when it comes to cruising and rowing through the gears and gas mileage, I love the T56 in my 98SS and I will be putting one in my next 2nd gen build.
Old 05-26-2008, 12:33 AM
cdoggy81's Avatar
04 LS1 is a good motor. Has the good rod bolts, an LS6 intake, & I think a good oil pump too.
How good of a deal are we talking about here? It would be cheaper to find a 2000-2004 LS1 with auto so you can use the computer & poss build the 4L60E up or sell it.
Old 05-26-2008, 12:58 AM
Super Speed's Avatar
To run an auto tranny you would simply have to have the PC flashed for it
Old 05-26-2008, 02:10 AM
Soul TKR's Avatar
yea... there fuggin ugly
just my opinion... so I don't want any PM's from anyone
Old 05-26-2008, 10:14 AM
Ryan L's Avatar
Just get an '05 with the 50 extra HP, better hood, and dual exhaust, etc.
Old 05-26-2008, 10:20 AM
LS1TECH Sponsor
Joey@Tick's Avatar
The 04 LS1 engine is great. You'll be very happy with it. Good luck with your project!
Old 05-26-2008, 10:27 AM
I THINK I can get the motor, tranny, ECM, Complete harness, T-56, driveshaft, crossmember, exhaust etc etc for $4K
It has 38K on it and the car was hit in the passenger front so the motor wasn't touched as far as I could tell.
I'm going to lowball the dude tomorrow and see what I can get it all for.
EDIT: I was going to put ARP rod bolts, cam, heads, etc anyway but that is good to know.
Old 05-26-2008, 10:29 AM
So the actual harness is the same then?
Old 05-26-2008, 10:53 AM
oops ....
Old 05-26-2008, 01:42 PM
The ECU harness is the same the transmission harness is different but they can be had for around 60$ or so
Old 05-27-2008, 08:45 AM
radkon's Avatar
If you keep the 04 GTO ECU you can run lean cruise and pickup a couple MPG too!
Old 05-27-2008, 09:22 AM
ArklaTexan's Avatar
When I was all motor 480rwhp Heads/Cam I still got 25mpg hwy while the 05/06 only get 21 if they are lucky.
