Help!! --a/c
Old 05-26-2008, 11:27 AM
jts98z28's Avatar
Default Help!! --a/c
Where's the low-side-port at?!?!?!?
story--its startin to get hot in NJ and i found out my a/c dont work, so i bought a recharge kit. it says the bottle will explode if i put it on the wrong port so since i like my hands the way they are i just wanna find out where this low side port is
---thanks
Old 05-26-2008, 11:42 AM
87Lt1Monte's Avatar
the Suction port is always the bigger of the two lines ..
Old 05-26-2008, 11:52 AM
2001NBMZ28's Avatar
Those kits should only let you connect to the low side.
Old 05-26-2008, 11:55 AM
jts98z28's Avatar
it has a warning label that says if i hook it up to the wrong port it explodes
Old 05-26-2008, 12:48 PM
DevilDougWS6's Avatar
yeah, its pretty dummy proof. and **** ac, it slows you down, dont you have t-tops? Where in jersey are you? come to my house i will fix it for you.
Old 05-26-2008, 01:07 PM
jts98z28's Avatar
traffic sux w/o a/c.
i recharged it but didnt work so i guess its sumthin mechanichal right?
Old 05-26-2008, 02:01 PM
grey03mach1's Avatar
Is the compressor coming on? Clutch kicking in and out? Need more info, "a/c quit working"....will be tough to diagnois.
Old 05-26-2008, 03:11 PM
9000th01ss's Avatar
LOL, sorry. Search general maintenance for ac problems. I've typed the WHOLE procedure every time it's been asked but I'm done.
Like I always say---if you came out and your tire was flat would you just put air in it and take off down the road? No, Why? because you know the air leaked out right? So where do you think your refrigerant went (if thats even the problem).
All the info is here somewhere.
