What size pushrods?
Old 08-10-2003, 01:39 PM
TanRchy's Avatar
Default What size pushrods?
what size pushrods will i need for my cam swap. I will be getting the GM ASA cam. It is a 226/236 .525/525 110LSA. So will i stay with stock size rods or something else? Thnx...
Old 08-10-2003, 04:23 PM
Tin Indian's Avatar
Default Re: What size pushrods?
I haven't measured the ASA cam, but, the ASA cam should have a slightly smaller base circle than the stock cam.
You should be able to get by with stock 7.40" rods, but you will have sightly less preload than stock spec.... No big problem.... Get a set of Thunder Racing 7.40" hardened rods. They are about .015" longer than stock. That will get the preload just about to stock spec.
Old 08-10-2003, 11:22 PM
pimpmaro's Avatar
Well the stock rods aren't QUITE 7.40". They are actually 7.380" if I remember correctly, but since most pushrod manufacturers dont' make those lengths, the best we can find is 7.40".
Old 08-11-2003, 01:31 AM
TanRchy's Avatar
sounds good. thnx...
Old 08-11-2003, 01:36 AM
STF veteran / 10 second club
x phantom x's Avatar
Yep ... I think that was what tin indian was getting at though, when he was saying the 7.40 is around .015 longer then stock (meaning the stock would be around 7.385 ish) Close enough for me.
