Help With Problem!
Old 05-26-2008, 04:00 PM
cubfanws6's Avatar
Default Help With Problem!
I have a spec 3 clutch and billet steel flywheel
Everytime I take off from a dead start you can feel something hitting when the clutch begins to engage in the clutch pedal...Sounds like something is rubbing..Once I'm in gear I can only feel the viberation in the pedal when I the clutch first enganges shifting into a higher gear..I'm going to pull out the trans and check everything over tomorrow..Does it sound like the throw out bearing or pressure plate??
Old 05-26-2008, 04:03 PM
wrencher
wrencher's Avatar
I'd bet that the pressure plate is the issue. You'll know for sure when the trans is out.
