CAT3
08-10-2003, 02:53 PM
Problems: Before cam, 150 shot yielded 11.4x @ 119 on ET streets. Now after cam, 150shot yields 11.4x @ 119 on DR's.
The 60' are .15 worse with DR's. Running the same AFR before to after @ 12.6:1AFR. No timing is being pulled either. My experience with DR's is it will normally yield higher trap speeds, but lower ET's when compared to ET Streets, yet I have matching numbers. I am thinking the LS1 Intake is really holding me back, but could it be the injectors as well, or is the nitrous power independent of the Inj. Flow Rate?
2000 Z28 with 26# injectors (yes the are over 80% 5000rpms, and yes I spin it to 6400rpms).
I konw with a set of heads I wil be cooking, but might the intake really be holding me back? I dynoed 346/366 and think maybe a 150shot is just a little too much. With a 100 shot I get 11.6 @ 117mph, btw.
TIA, Charlie.
TIA, Charlie.
