New Dyno #s
Old 05-26-2008, 06:47 PM
tacohen01's Avatar
Default New Dyno #s
So i dynoed my bird last monday. Turns out for the last year of having my car boosted, my throttle body has only been opening 62%. We fixed that and then dyno'd it again. Not too bad, but not enough to satisfy my needs yet...
482rwhp/540tq. I will post up the graph when I get home, I'm at work now...
Old 05-26-2008, 07:55 PM
allngn_c5's Avatar
100% tb opening made 482 / 540, what did she make with the tb only opening 62% ?
You got a Dr Torquenstein monster on your hands bro. Do you mind posting a bit of info about your setup ?? How much boost.
Old 05-26-2008, 10:43 PM
tacohen01's Avatar
Thanks, and no sir, I have no problem posting a bit of info about it. My last dyno run a year ago, at 62% was 446/498. So quite a bit of a difference.
I have an STS turbo kit with a
-gt67 turbo
-FMIC
-walbro 455 fuel pump
-new fuel pressure regulator
-fuel rails
-42# fuel injectors
-FAST LSX 90mm intake/tb
-SLP torque arm
-Nitto 555R drag radials
-160 degree thermostat
-Spec Stage III cluthc/alluminam flywheel
-electronic boost controller
-boost gauge
-aem wideband A/F gauge
-Blow off valve
-iridium spark plugs
-new map sensor
-new 02 sensors
-k&n filter
-slp subframe connector
-edelbrock headers - NEED Longtubes!!
-skip shift eliminator
-TCS reverse module
-driveshaft safety loop
-5.0 short throw shifter.
I ran 93 octane gas on the dyno, and I am pushing 10lbs of boost, but because the turbo is remote mounted, it only hits 10lbs for a second then loses a lb and stays at 9 through redline.
Old 05-26-2008, 10:45 PM
jetlag's Avatar
Awesome torque! Congrats.... got any track times?
Old 05-26-2008, 11:31 PM
tacohen01's Avatar
Thanks man, nope, no track numbers. I'm a little hesitant due to my stock rearend. If I brought it to the track I would probably take it easy off the launch, and that wouldn't be worth my 3 hour drive to the track. All we have here is an 1/8 mile.
Old 05-27-2008, 12:42 AM
Kingc8r's Avatar
Nice numbers, I'm sure it's fun to drive...
Kingc8r's Avatar
To say the least
Old 05-27-2008, 01:25 AM
tacohen01's Avatar
Ha, thanks. It gets me around... When I actually drive it....
Old 05-27-2008, 08:01 AM
allngn_c5's Avatar
Thanks for the info. Glad to see you got the TB issue corrected. Probably feels like night and day with all that torque you picked up.
Old 05-27-2008, 08:23 AM
bad95killer's Avatar
Very nice numbers buddy..Congrats
peace
Old 05-27-2008, 02:46 PM
tacohen01's Avatar
It does. I actually had a return spring from the throttle body fin to where the lid used to be. Now with that off, the throttle response and turbo spool up time is rediculous!
