Looking for the 2005 and 2006 N2o Fast Lists?
Yes, i tried search, but must be entering the wrong search words? Anyway, would like to link at least the 2006 list into the current '08 list as we have the '07 list already, but the adding the '05 would be just as good as adding the '06 list, however evn the '05 list would be as good as adding the '05 and the '06 list as well as the already posted and linked '07 list which is currently at the bottom of the '08 lists page which also contains the all time fast list which has cars from the '05 list as well as the '06 and '07 list, though the all time does not yet have any from the '08 list as the '08 list is not as complete as the lists from '07 as well as the '06 and the '05 fast lists, and further more i think it would get to confusing to add the '04 list to the already posted link of the '07 list and the posted '08 list and also the sought after '05 and '06 list, so we don't want to make this too confusing having anymore lists than the '05 and '06 and '07 with the '08 list really being the only one of importance, though the '06 list does have my 10.xx run whereas the '05 list has a slower time, but then again the list from '05 was pretty fast list, but I think that all lists from the years '05, '06, 07 and fianally '08 should be available should someone wnat to look up a time they had it lets say '06 and then they can compare that to a run in '08 as well as '05, but probably out of luck if they want to compare a run from '07 with a run from '04 as we are not sure about having the '04 list linked as the '07 list is already, but will be able to check against the '06 should that be wanted and furthermore having access to the lists from years '04, 05 '06 '07 and '08 would likely be too much information and become a little confusing for those that wish to seek a past time from one of the fast lists, but could check the all time and see if the run was added from the '04 list if it was fast enough, as the all time list may have years combined past the '05 cut off and that would open a new can of worms having say '03 added to the already posted link of '07 and '08, though if enough wanted we could add years '03 and '04 to the existing requested '05 and '06 then we would have years '03 '04 '05 '06 and '07 along with the current list, the '08, then you could cross reference '03 to any of the established years, like '07 and '08 and maybe '05 and '06 if we can find a link to them, and maybe even a link to the '03 and '04 lists would allow adding them to the requested '05 and '06 then we would have complete years begining with '03 and ending with '08 and having '04 '05 and '06 in between and oh yea '07 also, hope this is clear enough to make sense and if you having any suggestions regarding the years '05 and '06 let me know, though '03 and '04 are years worth making suggestions also as is the current lists '07 and '08, I didn't want to mention the next years '09 list as this may get people off track and we know how i like to keep things in order, thanks.
Robert
Robert
