zr1 didn't fit
zr1 didn't fit
Well I have some zr1 that where lying around my garage...I took them off my 00 ss and I wanted to put them on my 95 rs. I put the front ones on fine....but when I went to put the back ones on...they wouldn't fit..the zr1's are 17X9.5..
I thought that they would fit just fine.. Do I need to put a spacer or some sort of mod to make them fit...
the inner circle where the hub goes in has a lip around the ID. the 98+ rear axles were a bit smaller in OD than the early 4th gens. you have to grind that lip on the rims down with a hand file.
