Buying LS1edit next week. Where to start?
Old 08-10-2003, 07:29 PM
Moderator
LIL SS's Avatar
Default Buying LS1edit next week. Where to start?
I am buying edit this weekend and wondering what I should start with. 01 M6, mods in sig. Some ideas were:
Fans (On, off)
Changing the fuel tables from cell 0-21 (Using MAFT right now)
Adding timing (most I ever see is 24* @ 6k)
ASR??
Torque Management
Cat over temp (Does this work if I have cats but use O2 simms? See link) http://www.geocities.com/sqwznss/y_pipe.html
What else?
Old 08-10-2003, 08:55 PM
felton316's Avatar
Default Re: Buying LS1edit next week. Where to start?
Remove Torque management!! It woke up my M6 car.
Old 08-10-2003, 10:09 PM
jaywoo's Avatar
Bump your rev limiter, Diable cags, lower the temps at which your fans come on and off, if you don't have cats, disable the overtemp protection. There are a few other things also.
Old 08-10-2003, 11:25 PM
Cal
Cal's Avatar
No need to raise the rev limiter until you get the TR224 and new springs installed. 6200 rpm is about 1000 rpm above what the stock cam peaks at anyway.
Old 08-11-2003, 06:33 PM
strokedls1's Avatar
I didn't realize that m6 cars had torque management. How do you turn it off?
Old 08-21-2003, 12:06 PM
Dr. Evil's Avatar
Here's a link about removing it...
http://www.ls1tuning.com/forums/viewtopic.php?t=6
