what heads and cam for a 383 stroker?
Old 05-27-2008, 06:37 PM
chevyls1's Avatar
Location: where ever i can store my car. (palos hills,il for now)
Default what heads and cam for a 383 stroker?
ok i am going to get rid of my ported ls6 heads and my ms4 cam. i want more power. i have a stoker 383 an i was told that the cam was too small for the motor. and the heads are not going to flow enough.
let me know what you people think. i need to start looking in gettin this stuff.
thanks
cliff
Old 05-27-2008, 06:41 PM
firefighting1101's Avatar
a nice set of trickflows with a custom grind! the cam is the most important part of your build...no off the shelf cam is perfect for any specific build.
Old 05-27-2008, 06:53 PM
chevyls1's Avatar
what about speedinc custom grind stroker
Old 05-27-2008, 06:54 PM
chevyls1's Avatar
ssx i think its called
Old 05-27-2008, 07:08 PM
shdybrady1988's Avatar
if the cam is the most important part of the build why not choose the cam you want and base your build around that. Talk to ron at vengeance. They have a cam specifically made for stroker engines.
Old 05-27-2008, 08:48 PM
Fifedogg's Avatar
The MS4 is not too small for a 383 IMO. You just chose a cam that wasn't a match for your setup. Though I dont see your HP#'s so it might actually be a good setup. I will be using the smaller MS3 cam in my 402 build which is obviously bigger as far as CI's go. I have choosen that cam after I flowed my heads (243's) and had some people spec it out for me. It just so happened the MS3 was almost spot on to what I was looking for. My PRC 243's stoped flowing past .600" on the intake side @ 305 CFM and flowed 293 CFM at .650" on the intake as well. The MS4 isn't the best cam for the LS6 head IMO especially considering the .649" intake lift. I bet your 383 was over cammed if anything. A lot of people around here are all about peak HP #'s and not about all around driving, track times and Cobra Smokability How much HP are you looking to get out of her? Why not just throw a 150 shot on her and call it a day. Thats what I will be doing once my craving for speed needs a new heaping spoonfull of HP. Will it be a DD, or Weekend driver. We will need some more info to better assist you.
Old 05-27-2008, 09:20 PM
Grimes's Avatar
I say keep the cam and spend on a set of AFR heads.
Old 05-27-2008, 09:44 PM
TopFlite's Avatar
The MS4 is definately not to small for a 383ci. What are your plans for the car? Is this a street machine setup or a track one? Your heads and cam selection should depend heavily on this question.
Old 05-28-2008, 02:25 AM
chevyls1's Avatar
ok sorry more info would help i would like to drive the car on the weekend AND mostly i would like to increase my et. i am putting down around 442 rwhp. it ran in the 11's last year i would love to get into the low 10's this year.
Old 05-28-2008, 03:07 AM
smokinponcho73's Avatar
how do you like the setup now with the ms4 and stroker cause that is the exact build i was going to go with im going through texas speed for my shortblock though. just kind of trying to get some input on it. no one in my area have either a 383 or ms4
Brandon
Old 05-28-2008, 11:06 AM
Sigforty's Avatar
I know a few of the vette guys are running a Futral 239/243 that is used in most of his 383 builds. I ran that cam for a while as well, and it works very well. I only pulled it out to go bigger since I am not concerned with my low end so much anymore.
Old 05-28-2008, 11:37 AM
Bryan @ Speed Inc.'s Avatar
Our SSX that you mentioned has made some pretty good power in a couple 382 combos...
granted one was a 14:1 cr on race fuel.
but good heads are the key to making power on big cube big cam motors.
Old 05-28-2008, 11:48 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
WHAT!? A shelf cam matches what someone custom spec'd??? No way! WOW. [/sarcasm]
I agree, the Magic Sticks can be very good in 383-408ci builds depending on compression and the rest of the combo. Everyone gets so excited about CUSTOM grinds and forgets that before these cams were "shelf" camshafts, they were custom! Let us know how that combo works in your 402. I think it could be a blast!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 05-28-2008, 01:54 PM
CodeRed2000SS's Avatar
got a ms4 in mine, put down 470 @ the wheels on motor, just installed a little N20, will have track times friday....
Old 05-28-2008, 04:22 PM
turbotacoma's Avatar
No magic combo here. Stage 1 livernois heads, ls6 intake, ported stock throttle body, and a tr224 cam 114. Power at the wheels 423/434rwhp/tq. Yes, not a top end beast but the mid range is strong. 65 ftlb. more and 55hp more then the 346 (384/382rwhp/tq) it use to be. However, I am looking into a cam with 229/237 duration with a 113 overlap and .610" lift since the heads stall after .600" and at .600" they flow 305cfm.
Old 05-28-2008, 08:32 PM
BOTTLEFED383's Avatar
i had the ms4 in my previous engine till i blew it but hell 169k miles and sprayed like no ones business it was bound to happen but any how i chose not to reuse it anyhow i built a 383 with TSP LS6 stg 2.5 heads and Their Texas giant cam 248/254 .613 .622 114 it pulls good has good street manners which was important to me because ITS MY DAILY DRIVER im gonna start to spray it here within the next weeks if you use that cam you'll love it mid ant top end are killer
Old 05-29-2008, 01:57 PM
sounds good, the texas giant won't out when i built mine, but thats what i would have went with if it was
Old 05-29-2008, 03:18 PM
TXZ28LS1's Avatar
i would run a TFS heads/ VRX5.. that combo makes sick power
Old 06-02-2008, 11:21 AM
Ron@Vengeance's Avatar
Funny you mention that... We have had several 382s make 490s/480s with this combo on a good bottom end/full bolt ons
Old 08-12-2008, 12:17 AM
chevyls1's Avatar
hay ron that hp is that at the flywheel or wheels? what dyno?
thanks
Quick Reply: what heads and cam for a 383 stroker?
