EGR / AIR Removal 2000 Trans Am
Old 05-27-2008, 08:16 PM
Slowmaro305's Avatar
Default EGR / AIR Removal 2000 Trans Am
Ok i have just read through the sticky on top about the removal process and i think i got everything except one plug.
For EGR i have 1 block off plate and a 1 3/8" adjustable freeze plug
For AIR i have 2 block off plates. But i keep getting conflicting information regarding a vacum hose in the back. Is there one more thing to be blocked off on the back of the block or intake manifold? If so do i need another adjustable freeze plug and what size?
Old 05-27-2008, 08:32 PM
MjMaro's Avatar
There IS a spot in the back of the manifold for the AIR system that you will have to plug to prevent a vacuum leak, I wish I could help but I don't know what size it is, sorry. Hopefully someone will chime in that knows.
Old 05-27-2008, 08:34 PM
jsteele90's Avatar
i just stuck a screw in mine didnt have a vacumn cap
Old 05-27-2008, 08:35 PM
FAST LS1's Avatar
If you have the funds it's a great time to do the LS6 intake.
I did both at the same time since LS6 intakes were so cheap.
Old 05-27-2008, 08:36 PM
WS6_00's Avatar
yeah I just plugged mine up with a screw also, and some...lock tight i believe
Old 05-27-2008, 08:40 PM
Trunion King
bene's Avatar
Indeed, there is a T connection behind the intake w/ it connects to your AIR system and also connects to the A/C system, IRRC.
Old 05-27-2008, 08:54 PM
Ok thanks, this was the info i was looking for. As long as i know there IS something back there, i should be able to figure out a way to plug it thanks again.
FAST LS1 - I agree but right now the funds arent there for the LS6 so it will have to wait for now.
Thanks again everyone!
Old 05-28-2008, 09:30 AM
tylerdj's Avatar
I just used a screw that fit tightly in it and threaded it in there with some sealant.
Old 05-29-2008, 08:37 PM
NJgunslinger's Avatar
Hey tylerdj, what did you fit a screw into, the vacuum hose or a hole in the intake???
Old 05-29-2008, 10:23 PM
LS1-NAVY's Avatar
hose
Old 05-30-2008, 07:38 AM
Martin HD-28's Avatar
Are you talking about the vacuum hose on the passenger side or the t-shaped one from the drivers side?
Old 05-30-2008, 07:44 AM
tylerdj's Avatar
The vacuum hose. I used a 1 3/8" freeze plug for the hole on the intake.
Quick Reply: EGR / AIR Removal 2000 Trans Am
