Suspension & Brakes - Wheelhop help!
nahasapeemapetalon
05-28-2008, 09:06 AM
I have a 9" rear with welded on Relocation brackets. I have the lower control arms set in the top hole. The LCA's are lower in the back slightly angling up toward the front. Is it good to drop it even more on a stock ride height vehicle??
Any other suggestions?
It does it sometimes.
BMR Tech2
05-28-2008, 09:55 AM
Dropping the lca's down to a lower set of holes will help your wheel hop situation. Are you using stock LCA'S? Either way dropping down a hole will help you out.
nahasapeemapetalon
05-28-2008, 10:16 AM
I am using adjustable bmr xtreme control arms. There is no disadvantage to having the LCA's at too much of an angle?
BMR Tech2
05-28-2008, 10:20 AM
If you drive the car on the street alot the handling be compromised alittle if you use the lowest hole. If the car is strip mostly car the lowest hole would be the way to go.
nahasapeemapetalon
05-28-2008, 12:24 PM
If its only handling i could care less. Its a street/strip car.
Thanks!
M-Ten
05-28-2008, 04:44 PM
So the bottom hole is the best for traction? I also have your relocation brackets on my 9"
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
