Removeing the 10 bolt?
Old 05-28-2008, 11:38 AM
LM97Z's Avatar
Default Removeing the 10 bolt?
I'm going to start removeing the 10 bolt today in my 97 Z28 (3 sensor ABS) , any special things i should be prepaired for? Thanks
Old 05-28-2008, 11:41 AM
tbird31's Avatar
don't let it swing down into you if you're using a lift. if you're using jack and stands make sure it's supported well so it doesn't just drop right out of the car.
in the past 2 months i've removed and installed a 10 bolt in my car 3 times...lol. hopefully you won't have to do that...
Old 05-28-2008, 12:03 PM
LM97Z's Avatar
I'll be useing stands & a floor jack, i think i'm going to take the cat down also, so i can install a new pump while i'm at it, Hopefully this will be the only rearend swap i'll do, i'm installing a moser 9", this 10 bolt is still good, ain't takeing any chances with the 6sp.
