How do I make my LM-1 work with HPT Interface?
Moderator
First question, go to the Shack and get a stereo 1/8" headphone
cable and cut off one end. The LM-1 has two analog voltage
outputs, I think #1 is tip and #2 is middle band but check the
LM-1 docs for that. You need the shield and tip wires. Use the
default LM-1 transfer-curve settings and the default HPTuners
PID for the LM-1 and it should be good to go. But you may want
to take a minute and tap the LM-1 output voltage with a meter,
read the output unscrewed and screwed into the EIO block and
see if you get good agreement, just to make sure your vehicle
and wire-ball have no ground loop error contribution.
For a standard interface, I would (did, once) get an O2 sensor
pigtail and solder it to a 'phone cable and plug it into the rear
O2 position, set up the transfer curve for 0-1V on the LM-1 and
program the same scale into a custom PID in HPTuners. You can
also use A/C pressure or EGR ports at 0-5V if you have those
connectors handy or tap the wires.
I have the cord your talking about pos and neg wire with a headphone type jack that came with my LM-1 but I need the plug to plug into the side of HPT interface.Can I get this at Radio Shack?
Moderator
Plug should have come with the EIO cable. Little green block with
screw terminals which plugs onto the header posts. I know HPTuners
had some that they were selling pretty cheap at one time, the block
is kind of an oddball but they should either be able to provide you
one cheap or tell you the part / mfr so you can dig one up.
Less than $6 right here. http://www.hptuners.com/order.php
Thanks Guys and thanks for the link,I was going to go to HPT to find the part but just havent had timeSo this is all I need to make my LM1 Wide Band work with my HPT?
