1998 Z28 Cam + boltons equals
Old 05-28-2008, 07:51 PM
bigburb's Avatar
Default 1998 Z28 Cam + boltons equals
370 RWHP!!!
GM ASA Cam
LS6 valves springs
LS6 intake manifold
P&P Expoxied TB
Ported MAF
Pacesetter Ceramic LT's
Pacesetter Y
3" exhaust w/cutout
KN Air filter w/SLP lid
8.5 mm wires
NGK tr55 plugs
Walbro 255lph fuel pump
Props to HPE for getting the startup and AC problems fixed. See dyno graph attached. Pretty mild mods, good numbers. Thanks for the hard work Josh!
Old 05-28-2008, 08:40 PM
allngn_c5's Avatar
I'm too lazy to look up specs, so what are the specs on your cam ??
Do you have SAE numbers ??
Old 05-28-2008, 09:02 PM
landonew's Avatar
226/236 .525/.525 110 lsa.
Good numbers!
Old 05-28-2008, 09:12 PM
bigburb's Avatar
Good numbers!
Correctamundo
Old 05-28-2008, 09:19 PM
bigburb's Avatar
what is the approximate drivetrain loss on these vehicles for an M6?
Old 05-28-2008, 09:42 PM
BlkBird2000's Avatar
10-12% i think.... hp seems a little low to me..
Old 05-28-2008, 09:46 PM
bigburb's Avatar
Looks good to me, of course this is my first LS1. over 100 ponies for basically intake, exhaust and a mild cam. I'm sure with a more agressive cam and heads it'd break 400 easy.
Old 05-28-2008, 09:51 PM
connexion2005's Avatar
Nice numbers man! That's a pick up of 22rwhp and 21rwtq from without the cam...
Are those numbers corrected or standard? With a u/d pulley and some 1.8 rockers hello 385+!
I had the car since the weld in muffler and it's came a long way!
Old 05-28-2008, 09:57 PM
allngn_c5's Avatar
That is truly a baby cam. Not much more lift then stock, just a bit more duration on the intake, and a good bit of added duration on the exhaust side. Total sleeper for a cammed car. Good **** man.
Old 05-28-2008, 10:03 PM
firefighting1101's Avatar
very nice...that cam should run pretty good on spray too
Old 05-28-2008, 10:50 PM
twitchtwice's Avatar
before or after a nice tune?
Old 05-29-2008, 10:25 AM
The numbers are post tune...keep in mind everyone that the ls7 clutch increases the power lost through driveline just a bit...
Old 05-29-2008, 07:45 PM
GreenBlood's Avatar
nice numbers...does it beat the ground on that 110?
Old 05-29-2008, 08:00 PM
68birdls1's Avatar
If you mean sleeper as in quiet and non-letting off the hint of cam that is way off. This cam is a monster sounding cam.
Look up my buddy jbird and look in his sig for his results.
Old 05-30-2008, 12:10 PM
got milk??'s Avatar
nice numbers if you got a set of heads and the pulley dont be surprised if you pick up 60 plus rwhp the 98 heads are not complete junk with a stock cam but when a larger cam and ls6 intake is in the mix they rob you a good amount because they are acting like a bottleneck.
Old 01-29-2009, 12:55 PM
UTfan01SS's Avatar
I hate to bring back an old thread but why does the torque drop of so quick above six grand? It looks like a very aggressive cam under the curve but not much of a top end performer. The HP looks good though, could someone explain that to me?
Old 01-29-2009, 03:34 PM
WSsick's Avatar
most people think lift has to do with the idle sound. thats all in the duration/overlap & LSA.
Old 01-31-2009, 07:08 PM
firefighter813x's Avatar
Correct me if im wrong, but it should have 11* overlap. That should lope hard.
