what do you think about this exhaust idea
Old 05-28-2008, 08:54 PM
bad6as's Avatar
Default sprial flow off y-pipe???
edelbrock long tubes, edelbrock off road y-pipe, then a cut out on the tip of the y-pipe then on the cut out a moroso sprial flow.?
would that be louder then my lm II cat back?
regardless i want the cut out as close to the y-pipe is possible. but as fas as the sprial flow i dont know if i should put a pice of pipe between the cut out and the sprial flow or if i should put a pice after the sprial flow or both?
any ways will the dumped sprial flow be quietier then the lm II cat back, and is the sprial flow the quietest bullet?
Old 05-28-2008, 09:17 PM
BlkBird2000's Avatar
I think it sounds alright. The cutout is going to be louder than your LM II I would think anyways. Try it and get a sound clip. Keep your old **** just incase you don't like it.
Old 05-29-2008, 07:41 PM
bad6as's Avatar
any 1 else?
Old 05-30-2008, 04:42 PM
hlaalu's Avatar
im not sure if i read this correctly, u want to have your cut out going to a muffler? why not just the cutout?
Old 05-30-2008, 07:59 PM
bad6as's Avatar
the cut out will have on end on it, the other end will have a muffler
Old 05-30-2008, 08:01 PM
bad6as's Avatar
black is my y-pipe, red is cut out, yellow is the muffler
Old 05-30-2008, 08:04 PM
bad6as's Avatar
or the same as above but after the 1st muffler have a pipe going over the axle (blue) and then another muffler
Old 05-30-2008, 09:57 PM
hlaalu's Avatar
oh then yea i think thats a good set up.
