I got T56 problems.
I got T56 problems.
I don't think its too terrible, but tonight I played around in the car a bit a couple doughnuts and a run through the gears just because I don't really beat on it much. Well everything was fine until about 45-min later It starts making noise when I put it in gear, but not everytime. It's not a grinding noise like a synchro, more of a vibration and a small whirring sound.
I don't know anything about a T-56, so if someone could help me out that would be great. It's been a while since the fluid has been changed so I'm going to do that tommorow.
Thanks.
Thanks.
That's a relief,thanks. I just went out and drove it again and there is def. a vibration at a higher RPM, but if i wait a second in between shifts its works fine. But I am going to change the fluid hopefully that will solve it.
If you slipped the clutch significantly, you could have burned segments and an out of balance piece.I doubt it will recover from this. An oil change won't hurt but I think it will do nothing for the vibe.
