Which Headers?
Which Headers?
I am going to put some LT headers on my '00 SS but don't know which ones to buy.
I have a line on some Pacesetters, Flowtechs, and Hookers. Of these can anyone one tell me which ones are the:
1. easiest install
2.best fit
3.best performer
Thanks
1. easiest install
2.best fit
3.best performer
Thanks
I only have experience installing Pacesetters and QTPs...
Pacesetter are definitely super easy to install... QTP was a little bit of a pain in the ***.
On Pacesetters you will have to cut a small casting tab off the driver side of the block..then the header will slide right in. A sawzall will slice through it like butter.
Do I need the ones with the EGR and A.I.R. PIPE? If I go with off-road ones what do I have to do to use them?
Thanks everyone for your help. It sounds like the best way to go is the pacesetters or hookers that are coated.
My next step is going to be adding an LS6 intake and a head/cam package from cartek. Either one of these headers should be fine with that setup - I think.
x2 on the Hooker LT's!!!! I got mine, ceramic coated with 02 extensions, Y pipe, and 02 sims for $477 shipped.
mine slid in like butter on a shaved kitten, I didn't have to do any grinding, remove any parts other than the factory manifolds/cats or fight anything to get them in...the hardest part was starting the bolts. Ground clearance is the best part of these. Speed Inc sent me a Pacesetter Y pipe and it fit like absolute crap, I bought the Hooker Y pipe from Jegs and it fits like a glove.
