Anyone know how to hook up kickdown tv cable to 700r4 to ls1?
Old 05-29-2008, 01:47 PM
CalSpeedPerformance's Avatar
Default Anyone know how to hook up kickdown tv cable to 700r4 to ls1?
I just finished ls2 conversion into 69 camaro and we reused the race built 700r4 the car had. The problem I have is I need to hook up the kickdown TV cable to the ls1 throttle body.
Anyone know a source on this?
Old 05-29-2008, 02:09 PM
leonpiper69's Avatar
i know the iroc tuned port motors used the same type of throttle deal as the ls1 just on the other side. i wonder if you lookat how those are hooked up you could copy it just opp. sides.
you may just have to drill a hole (in the right spot) and put it the round thingy the tv clips to?
Old 05-29-2008, 04:25 PM
LS1MCSS's Avatar
It all depends on what type of throttle body you are running. If it's DBW, you will have hell. You may have to go to a manual valve body. If you have an early(98-99) style body, it's easy. Bowtie Overdrives makes a kit that will work on that throttle body side plate. If you're running an after market throttle body, you have to engineer a mounting point and bracket like I did. Here is a website with the correct geometry, http://www.chevyhiperformance.com/te.../photo_07.html , and that's extremely important. You will also need the TV cable from Lokar. Here is a picture of my setup.
Old 05-29-2008, 07:37 PM
Indyjc's Avatar
I'm using the iroc tv cable set up. I made an L shaped bracket welded it to the stock tb. There is a throttle cable bracket on the pass. side of the intake that is what I attached the tv cable housing to. My 700r4 works great with my ls1. Good luck
Old 07-04-2008, 01:00 PM
raidmagic's Avatar
Can you offer up any pics of your setup. I am getting ready to start this swap in m 87 Corvette and the tv cable hook up was a concern of mine. Thanks
Old 07-05-2008, 04:16 PM
Indyjc's Avatar
I will try in the next day or two. Working Sat. and Sun. and mowing Sun. nite but I will do my best.
Old 07-08-2008, 03:04 PM
mobythevan's Avatar
I have one of the bowtie overdrives TV cable kits for the LS1. I changed to a powerglide last winter. PM me if your interested, I'll make you a smokin deal on it.
The kit is SOLD
Old 09-30-2008, 02:24 PM
raidmagic's Avatar
Any luck on the pics? I ordered the Lokar cable so I'm good there just want ideas on the mounting bracket. Thanks
Old 09-30-2008, 02:53 PM
El_Diablos_Buick's Avatar
I take it that this will be the same for a 200r4??
Old 09-30-2008, 03:07 PM
LS1MCSS's Avatar
Yes, they work the same.
Old 09-30-2008, 05:43 PM
Stu Cool's Avatar
I remember reading a post from someone on here that made a hybrid cable--->ETC. He used a conventional cable and ran it through the firewall to a modified ETC contol unit he had cut up from a Corvette or truck pedal. That then controled the throttle body. He had his TV cable hooked up to the cable connection point. I wish I could remember the persons board name. It was done very cleanly and I believe he had cruise control integrated into it.
Pat
Old 09-30-2008, 08:54 PM
6spdgto's Avatar
Pat
It's someone that posts often as I read him talking about that within the last two days.
What's preventing you from connecting this cable alongside the throttle cable at the pedal? That's the way they connected the kickdown cable on my Skylark from the factory.
Old 08-25-2009, 08:37 AM
jeeperanthony's Avatar
sorry to revive an old thread, but any pics?
Old 08-02-2011, 02:38 PM
86vetc4bang's Avatar
im kind of curious about this as well.
Old 08-04-2011, 04:59 AM
downset71's Avatar
using GTO setup. made the cable bracket and welded pin onto lever. will take some pics for you
Old 12-09-2011, 08:13 AM
pjku79's Avatar
Still waiting on pics. I just installed an LS1 and want to get rid of the th400 for a 4 speed.
Old 09-16-2012, 01:03 PM
5.3 cutty's Avatar
bump!!!!!
Old 09-16-2012, 06:16 PM
downset71's Avatar
Old 09-16-2012, 06:17 PM
downset71's Avatar
Old 09-16-2012, 06:18 PM
downset71's Avatar
made tab and welded to my 04 gto throttlebody. mount was altered to receive 700 kickdown cable made by Lokar universal.
Quick Reply: Anyone know how to hook up kickdown tv cable to 700r4 to ls1?
