injector ?
injector ?
i was wondering if i could benefit from larger injectors, i have a 04 Z with these mods,vararam,highflow airbridge, dynatech longtubes,x-pipe, hi-flo cats, comp cam 231/234/643/598/ 111 lsa, prc dual springs, titanium retainers, ls2 timing chain, 426 rwhp 400 pounds torque,thanks in avance!
1 Post
What is your duty cycle ?? I have been told when you exceed 80% at WOT you may consider upgrading unless we're only talking about a few % points over 80. I am sure someone much more in the know will respond to this and help you further. Good luck.
BOSCH 30lbers will be fine. 42's would be better if your upgrading in the future. My 42's were at 98% duty cycle....and they can go higher, just watch the AF ratio. Not recommended but,...doable. Seen 30lbers on 600rwhp cars and 900 on spray.
I'd buy 38-40's if these are the end of your mods.
