Only 362 hp??? w cam...
I just had my 98 vette dynoed....it has varaam cai,85mm maf,ported tb,ls6 intake,bbk shorty headers stock cats,bb catback,232 238 595 595 113+4 lunati voodoo cam,beehive valve springs,7.4 pushrods....m6 it only dynoed 362hp 348 tq wat could be wrong??? could a bad fuel filter or plug wire cause this?? car feels strong on the street but it should have dynoed higher...it was a dynojet at brenspeed any info...is something prolly wrong?
what injectors? i have the mods in sig and it's a smaller cam and made 391rwhp. either injectors are bad or you have more serious problems(compression low). Plugs COULD cause it but i doubt it. Is it missing at all? Change 'em out and change the fuel filter and see where that gets you. That doesn't fix it try getting fuel pressure checked and then compression and leakdown. If your running stock injectors your WAY to low on fuel.~Cole~
Unless the car has 4:10 gears that you're not telling us about, I'd say it's kind of low. As mentioned earlier, I would do a compression and leakdown if the other stuff checks out fine. Good luck man, and don't get to caught up in dyno #'s since you said it runs strong. Take it to the track and see what it does.
guys are making almost this hp w just boltons...let alone me having a cam...it should be around 375 380 w my setup...400 w longtubes....many people have said this
the 97-98's have the most restrictive computers. I know it is not a corvette, but I have a friend with a 98 camaro z28 with a 408 and he is stuck throught the stock maf because the computers are so restrictive. So see what the tuners did with that and also you are running through shorties and stock cats. i would also check what the other guys have said, and what injectors are you running? Best of luck with the problem and the car looks great in the pic. very clean and sharp looking.
btw what rear gears are in the car?
That is my point. If you were 330 without the cam and swaped out your shorty's for some long tubes, that would jump to around 350-360. Now add your current cam into the mix and you have a solid 400hp+ setup. Your at 360 now so just think what is going to happen once you let the car breath. Also this is still through the stock CATS! I don't know if any one else that has stock CATs. They are all aftermarket. There is nothing mechanically wrong with your car other then it needs to breath.
