Dynoing tonight, any estimates for combo...LSx/S95
Old 05-30-2008, 08:35 AM
7 Second Club
Phil99vette's Avatar
Default Dynoing tonight, any estimates for combo...LSx/S95
Here is what we're strapping down.
438Cid LSx
ET LS7 heads
GMPP Carb Manifold
105mm TB
Chiseled 3000hp IC A2W
S95 turbo
Stef's Dry sump
160# injectors
Solid Roller(260/254) ~.700 lift
Jesel J2k Rockers
Glide
3.50 rear
8.5:1
Tonight we aren't going to hit it hard, maybe 10-15psi. Looking to get the car to run strong at those numbers, will work on fuel and timing to get a big number under the curve. Inital plan is to make pulls to 8k or so and see how the turbo likes it. Any guesses?
Old 05-30-2008, 08:41 AM
SPRAYED 01's Avatar
450WHP. Probably a high 11.
Old 05-30-2008, 08:46 AM
98transguy's Avatar
10 psi i will go with 768hp/775tq 15psi 889hp/832tq
Old 05-30-2008, 08:50 AM
jamnut's Avatar
Knowing the compression would help with the guessing a little.
Old 05-30-2008, 08:53 AM
7 Second Club
Old 05-30-2008, 09:17 AM
417 Motorsports's Avatar
I think hes in the ball park
Old 05-30-2008, 09:28 AM
LS1TECH Sponsor
DrTurbo's Avatar
Phil what size stall??? If its a big one it will eat into those #'s.
Old 05-30-2008, 10:05 AM
I made 640 on 12psi with a stock 6.0 bottom end and stock l92 heads with a 4500 conv. and a glide, on a freakin mustang dyno!! so i think he setup should have no problem bustin those numbers lol
Old 05-30-2008, 10:10 AM
NA$TY-TA's Avatar
7.... 7 HP PHIL....
Im sure it will be enough
Old 05-30-2008, 10:27 AM
7 Second Club
Don't know what stall it is. Its a Neal Chance bolt together converter with a hard hitting stator and its set full tight. I'm hoping for something in the 7s on low boost.
Old 05-30-2008, 11:09 AM
99.9percenter's Avatar
1200 Your car is too cool.
Old 05-30-2008, 12:56 PM
helicoil's Avatar
Default Car
Real nice job! Good luck with the numbers.
Old 05-30-2008, 01:29 PM
Reject's Avatar
i'm a say about 325
lol
man get it on video though!!
Old 05-30-2008, 02:10 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'll go with 763rwhp 10 psi, and 920 at 15 psi. Good luck either way, though you are a helluva fabricator and I'm sure the car will do some good things.
Old 05-30-2008, 04:04 PM
1dirtyZ's Avatar
is it done yet
Old 05-30-2008, 04:07 PM
LS1TECH Sponsor
DrTurbo's Avatar
Phil what rpms do you plan to rev the motor to? I'll stick the #'s on a HP calculator I have. See how accurate this is...
Race your car!
JL ws-6's Avatar
I'll guess at 10 psi probably 700 rw, at 15 it's gonna be over 900 rw
Old 05-30-2008, 04:21 PM
LS1TECH Sponsor
DrTurbo's Avatar
Ok just for giggles....
Lets assume 7K RPM's, 15psi, your intercooler will have about 2psi drop or so, and outlet temps should be about 80-90 degs at the end of the run, though this is hard to assume since it will depend on how much ice water is flowing through per minute.
Your back pressure should be about 1.47-1.42:1, assuming EGT's stay around 1500-1550 or so.
comp efficiency on that unit should be around 72% judging by the #'s. That means the motor should make around 1205 crank HP. Hard to say what % to take out for stall and auto, but that would put you around 964rwhp assuming 20%.
Old 05-30-2008, 04:26 PM
camarols1's Avatar
760 @ 10psi and 975 @ 15psi ????
Good luck Phil, you have a truly amazing build there!
I think the turbo vendors on this site owe you a little something for all the business that your build drummed up for them.
Old 05-30-2008, 04:27 PM
Todd157k's Avatar
(cuz Dr.Tubo lost me after "Let's assume")
my dumbass guess is that your car is going to freak out the dyno and you won't get a good reading.
Quick Reply: Dynoing tonight, any estimates for combo...LSx/S95
