Possible other options for DVC sail panel subs inside
that sounds good to me, ill be ordering 6 if you are able to get some !
Do not buy the Goldwoods. 2mm Xmax. The 4" MIDRANGES I use in my home speakers do 3mm. They are the kind of speaker I would recommend if you will be selling your car and need to put cheap speakers in it. And that AC has (almost) nothing on the Tang Band, though it's not bad. It'll be louder with a low-power amp (like stock) but it won't go as low.
Yep, they do. They're a great place to buy from. Those ACs should be a pretty good choice for DVC (go Peerless SLS if SVC is acceptable). Just keep in mind that 7" speakers rarely fit in cutouts for 6.5/6.75"s.
