pinouts for an 01 gmc sanoma 2.2?
Old 05-30-2008, 05:46 PM
leonpiper69's Avatar
Default pinouts for an 01 gmc sanoma 2.2?
anyone where to get the pinouts for these 3 plugs c2 (the black retangle box that plugs into the fuse /relay center (sanoma)
and the pinouts for these plugs for an 01 5.3
c100 and c152
stumpted
Old 05-30-2008, 06:09 PM
Black X's Avatar
2001 Sonoma C2
Old 05-30-2008, 06:15 PM
Black X's Avatar
Old 05-30-2008, 06:16 PM
Black X's Avatar
Old 05-31-2008, 11:11 AM
sweeeeeeeeeeeeeeeeeeeeet.
Old 05-31-2008, 11:39 AM
Black X's Avatar
your welcome
Old 05-31-2008, 03:20 PM
hey black x, do you have the same type pinout for the 01 5.3 connecter?
the only info i got has the bare bones but not all the pins i may use.
thanks dude.
Old 05-31-2008, 08:56 PM
Black X's Avatar
Which 01 5.3L connector are you looking for?
Old 06-01-2008, 08:06 AM
the black rectangle box c2. the one you put up for the 2.2 was perfect, but the info i found for the 5.3 was not as complete as what you gave me for the 2.2.
and any chance you have the c100 for the 5.3 too????
plus can you drop the motor in with the maniflods on? we were starting to see how it would fit last night and they dont clear, so i figure we have to put them on after the motor is bolted in?
Old 06-02-2008, 01:56 AM
Black X's Avatar
Old 06-02-2008, 01:59 AM
Black X's Avatar
I cant seem to find the C 100 for the 5.3L what shape is the connector?
What manifolds are you using? I use the sanderson headers and I usually put the motor in with the drivers side on and then put pass side on in truck
Old 06-02-2008, 08:42 AM
first, thank you dude. and second we are trying to use the stock manifolds (i think i read they will fit). the c100 is is the same black 16 pin connector. the sanoma has one and the 5.3 has one but the colers of the wires dont match up, so i figured we could just repin it.
Old 06-05-2008, 05:36 PM
x, you there?
Old 06-05-2008, 06:04 PM
Black X's Avatar
c100 AND C152 posted above are for the 5.3L
Old 06-05-2008, 06:06 PM
Black X's Avatar
This is the closest thing I can find for the 2.2L but its C101
Old 06-05-2008, 10:22 PM
hey x to the z, i screwd up. my buddies truck is a 98 sanoma not an 01. i thought he said it was an o1 (long story). do you know if its the same pins for a 98 and an 01. the other stuff matched up for the big rectangle thing so i figure its probably the same i just thought i would ask the almighty x to the z.....
Old 06-06-2008, 08:50 PM
Blazin2wd85's Avatar
thanks for the info black x, do you know if the c101 plug is the same for a 4.3 as a 2.2?
Old 06-07-2008, 07:49 PM
cavmattz24's Avatar
hey x to the z, i screwd up. my buddies truck is a 98 SONOMA not an 01. i thought he said it was an o1 (long story). do you know if its the same pins for a 98 and an 01. the other stuff matched up for the big rectangle thing so i figure its probably the same i just thought i would ask the almighty x to the z.....
Fixed that for ya..
Old 10-30-2011, 10:07 PM
reganm16's Avatar
Default Instrument Cluster Diagram
Does anybody have the diagram for the gauges on a 2001 s10? I'm swapping the 5.3 into my xtreme that originally came with a 2.2 and need some help with making the gauges work. i understand i have to recalibrate the tach and all. Thanks. I'll post some pics up of my truck. its not too much but i'm trying to do the most with it.
Quick Reply: pinouts for an 01 gmc sanoma 2.2?
