Hydrallic roller lifter install
Old 05-30-2008, 06:45 PM
sparkwirez06's Avatar
Default Hydrallic roller lifter install
Which way is the hole in the outside top of the lifter to be positioned? I took out the lifter tray and removed a lifter, the hole was to the top of the engine, took out another it was the same, took out another it was on the bottom, seemed to be no pattern, does it matter? THANKS
Old 05-30-2008, 08:10 PM
ShevrolayZ28's Avatar
It doesn't matter.
Old 05-30-2008, 08:14 PM
That's what i thought, i put every other one, figured that to be a bleed off hole. THANKS
