Fidanza aluminum flywheel & LS7 clutch?
Old 05-31-2008, 12:23 PM
02Z28LS1's Avatar
Default Fidanza aluminum flywheel & LS7 clutch?
will the Fidanza aluminum flywheel & LS7 clutch/pressure plate work together? i'm assuming they will, since Byunspeed has the same Fidanza aluminum flywheel part number for both 98 - 02 LS1 f-bodies as well as the 2004 - 2006 GTO's.
Old 05-31-2008, 12:32 PM
ennovations's Avatar
I am pretty sure that they will work together but from my research, an LS7 clutch with a Fidanza flywheels weighs the same as a stock LS1 clutch and flywheel. So, if you are going for a lightweight rotating mass I don't think this is the way to go. But I don't have any personal experience with this, it's just what I've read.
Old 05-31-2008, 01:34 PM
04BlueSS's Avatar
Make sure you get the Corvette specific one PN:198171 the LS7 clutch won't work on the LS1 version PN:198571.
Old 05-31-2008, 06:55 PM
02Z28LS1's Avatar
so by getting the corvette-specific flywheel and the LS7 clutch/pressure plate, are there any other parts that i will need to get while i'm in there that won't be standard LS1-based parts?
Old 05-31-2008, 08:34 PM
04BlueSS's Avatar
Nope that should be it.
Old 09-06-2008, 12:29 PM
spaz1's Avatar
Did you do this yet? I want to run this same setup.
Thanks,c
Old 09-08-2008, 09:41 AM
toneloc60's Avatar
I'm running the LS7 w/fidanza. Make sure you get the LS7 style flywheel. They are different than LS1s and won't bolt up.
Oh, and running the stock LS7 PP & flywheel you'll gain 7 pounds total. Running the LS7 PP & Fidanza you lose 5 pounds total as there is a 12 pound difference.
Quick Reply: Fidanza aluminum flywheel & LS7 clutch?
