Speedometer Change
Speedometer Change
I had 4:10 installed at CMS my M6 Z28 Camero and the Tire size was then 275x35x18 Ryan changed my computer to the new gears and current tire size.
I now put on New Rims and Tires today ( 255x45ZRX17)
My question is how much is my speedometer off since I went to the New Rim and Tire size?
Any input would be greatly appreciated
Thanks in advance
Bruce/StoreKeeper99Z28
__________________
99Z28/M6/ Pro 5 and Lou's "Short Stick"/ AAP Custom Y Pipe 3"/ 4:10 Gears CMS/MMS Aggressor Cam 233/233/578/578/113 lsa/Mac Mid-Lenth Headers/Don lee Auto Ported Throttle Body and Ported LS6 Oil Pump/AAP 6.0L Heads/SLP Dual Cam Roller Chain/MMS Mike Morgan e-Tune,Dyno Tuning.
Dyno: Sept 9,2007
439 RWHP/398 Torque
Thanks in advance
__________________
Dyno: Sept 9,2007
439 RWHP/398 Torque
If they have your tires on tirerack.com, you can check the diameter under "Specs", see what the diff is.
Or, I just found this:
http://www.powerdog.com/tiresize.cgi
Edit: Oops, that didn't help much. Only gives specs.
