shocks?? 60'
Old 05-31-2008, 04:51 PM
trans99am's Avatar
Default shocks?? 60'
could new shocks change what kind of 60' times i get. I am not getting the 60's like i did a year ago and wondering if something on my suspension wore out and wont sag anymore.
Old 05-31-2008, 05:18 PM
deadmanTA's Avatar
The guys in the drag racing sections on here swear by the QA1's.
Old 05-31-2008, 07:26 PM
Manic Mechanic's Avatar
I had a sagging front spring and coundn't 60'.
Vernon
Old 06-01-2008, 03:08 PM
trans99am's Avatar
dang a bad front spring affected you that much? another told me about bad bushings affecting his 60' times also. I couldn't get below a 2.3 and i was constantly getting 2.5. Last year i was consistent 2.3 with some 2.1's. anything i can check for to see what is bad?
Old 06-01-2008, 03:16 PM
djsanchez2's Avatar
Wow you could damned near idle off the line and cut a 2.4 My big "issue" was my tires. What does the rest for your susp. setup consist of?
Old 06-02-2008, 02:23 PM
trans99am's Avatar
120 k miles stock suspension. and i basically had to idle off the line to get it not to spin. and it would bog of course when i left real easy. Like I said I'm just wondering if anyone has seen dramatic improvmeents in 60' times after replacing something minor on there suspension components.
Old 06-02-2008, 03:11 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Transam, there are alot of other factors involved in cutting a good 60' other than shocks. We have the best tech dept in the business and can help you make the right choices. Some of the fastest stock suspension cars in the country use off the shelf BMR parts. Give us a call and we can go over your setup and make suggestions. Our tech hours are MON-FRI 8:30AM-6:00PM EST.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 06-03-2008, 08:32 PM
djsanchez2's Avatar
A tire would be the most dramatic change as far as traction goes.
