Bleeding off boost
Old 06-01-2008, 01:48 AM
TransAmcoupe98's Avatar
Default Bleeding off boost
I have done a search on a couple of sites and couldn't find what I was looking for. With the cam I have now, multiple people told me that it will bleed off boost due to the LSA being a tight 112. Bleeding boost...does it mean that psi it drop and spike randomly or not run the right amount of psi the spring is set at?
Old 06-01-2008, 09:28 AM
deadmanTA's Avatar
If it's the cam in your sig, then I would try it. It would do better with a higher lsa, but I don't think that cam is agressive enough to hurt you.
Why the 112 with an auto anyways. Did you want the extra lope?
Old 06-01-2008, 09:44 AM
LS1Tech Sponsor
Slowhawk's Avatar
On the turbo the wastegate will hold the boost level but with a Cam bleeding boost the turbo will be spinning harder to make that boost level compared to a cam that holds more cylinder pressure.
Old 06-01-2008, 10:38 AM
Jake@EPP's Avatar
The turbo guys have a bit more of an issue with it then the blower guys. The turbo will spin harder to make that boost. A blower will show less boost but some tests show overlap is a good thing, it tends to clear the cylinder with that "bled" off boost, less boost same power.
Old 06-02-2008, 04:14 AM
Yea, just for the lope. Had no idea I was going turbo until I deployed and got some cash.lol. O well, If it hurts performance too bad, I guess I'll pull it...Since I'm made outta money
Old 06-02-2008, 07:35 AM
Dumb Ass Vette Moderator
ls1290's Avatar
If you are going to pulley it to change the LSA, you could also increase the durations a little to match your 3400 stall.
Keith
Quick Reply: Bleeding off boost
