C6 OEM 19'' rear?
C6 OEM 19'' rear?
I have a formula, and i just purchased a set of OEM c6's split spokes (not Z06's). I have 1.25 adapters to go with the set. My question is, with the spacers and the offset of OEM 19x10's, can i fit a 285/35/19 with no BFH mod. Also can i fit 295/35/19 without the BFH. Note: car is lowered. A
As always any help is appreciated.
i think i just had these on last week me and my friend traded rims he and a adapter too,,,
19 on the back 35 on my lowered car only problems is you might want to roll your fender in or hammer it it or else it might rub on the tires he and that was with 295 35 19
Did they rub on your car when you had them on?
275/30/19 here, lowered with Eibach Pro-Kit (1.2" drop), 1.25" adapters. No issues, no rubbing, everything fits fine with my OEM C6 19x10 with 79mm offset rims.
There's a post about this over at www.camaroz28.com that's a sticky in their wheels and tires forum that says that 285/35/19's will fit just fine with the 1.25" adapters...however, I have NO idea if that holds true if the car is lowered.
