Pontiac GTO 2004-2006 - 2006 gto diff.
View Full Version : 2006 gto diff.
armyGTO
06-01-2008, 02:27 PM
i was just wondering if the 2006 gto's came with the 7.5 differential? i was looking for it around the forum but i think i just wasnt looking right. help out please. thank you
massillongoat
06-01-2008, 03:03 PM
umm I"m not sure I know its a 10 bolt though
Devinsgn
06-01-2008, 09:47 PM
Its a spicer (Dana) M80 not sure what size it is, its an IRS. They are all the same size in the 04-06 GTO except the 04 has a smaller pinion flange then the 05-06 (LS2) cars which was required for the larger drive shaft. So all the internals are interchangeable. Theres only 1 company that makes gears for it and the tallest gear available is a 3.91. So the parts are limited for it. What exactly do you want to know about the diff?
Phantom_LS2
06-02-2008, 07:52 AM
Am I correct when I say that the GTO independant rear is completely different than a vette's? There is no swapping parts between the 2 right?
Devinsgn
06-02-2008, 11:19 AM
Yes you are correct. They are completely different.
armyGTO
06-02-2008, 06:44 PM
i hear that the diff. on the 06' GTO are junk. i am trying to figure out a way to beef it up or something.
Devinsgn
06-03-2008, 11:20 AM
Who did you hear that from? There was problems on many 04s that whined and thats about the only problem with them (they were replaced under warranty). I know a few people who run high 10s on these diffs without any problems for the past 4 years. I have over 80 12 second passes on a stock diff in my GTO with no problem at all.
The best thing to do with the diff is get 3.91 gears and a spring tuning kit.
PapaSmurf2005
06-03-2008, 03:35 PM
The rear ends are ok for what they are. Some people get into the 10's with them while some break them in the 11's/12's. I've already had to have mine replaced. Either way they are very loud, they clunk and whine, but that is normal.
Phantom_LS2
06-03-2008, 03:57 PM
What did you replace yours with? Rebuilt stocker? Kaaz? Something else?
