Gears & Axles - Removing rear end?
x2jesse1x
06-01-2008, 09:10 PM
I am wanting to remove my rear end from my firebird. I have never removed one befor. what is all involved and how hard is it? I have a donor 10 bolt housing that is pretty much brand new to replace my rusted one on the car. I want to take the internals from the old one and put them in the new one. Any links to previous threads or advise would be awsome. thanks
SS SLP2
06-01-2008, 10:32 PM
try these think some will help
10 BOLT REBUILD
http://www.fullsizechevy.com/fscu/axletech/
http://www.thedirtforum.com/differential.htm
http://www.drivetrain.com/ringpinioninstal.html
tatasta
06-19-2008, 10:23 PM
Is there anything wrong with your current rear end or is it just rusty? If just rusty, paint it. Don't be stupid. If you don't know what you are doing, it will kick your ass.
Bad Blue WS6
06-20-2008, 08:59 AM
I disagree, I have never done one, and had mine out within about 3 hours from jacking up the car,,with beer breaks. :chug:
i used a writeup made by a member here, made it pretty simple...do some searching, the gears and axel section isnt huge,,like 5 or 6 pages
http://www.ls1tech.com/forums/showthread.php?t=514327
Good luck and have fun!!
RsSean
06-20-2008, 09:16 AM
Removing the rear end is not that hard. Just a few bolt LCA and the brake line that attaches to the rear end on the left side of the chunk, I take the brake calipers off the rear to avoid bleed the brkae and fluid messes. The lower shock bolts. Driveshaft, Then the rear end should be ready to pull out. If I am missing anything some one will correct me.
Now to the switching of gears, is a different story, blacklash depth of gears need some practice on that. Hopefully someone can really give some better help on setting the gears up.
Bad Blue WS6
06-20-2008, 09:23 AM
id be scared myself,,but here is a great write up..(this gal knows whats up)
http://www.keliente.com/gears1.htm
RsSean
06-20-2008, 07:33 PM
Talk about a good right up!
speedthrillsme
06-22-2008, 08:43 AM
Did mine yesterday. Me and my buddy had mine out swapped all the brake stuff put new pads, rotors and brake fluid in. We did it in under 5hrs.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
