How do i Set up PID's to measure RAF?
Hey guys, im using HPtuners trying to log Base Running Airflow in Gear and in PN. How do i set it up so that it will work? I have a couple .cfg's already that "are" set up to log this but when i go into the histograms it says "This histogram is not supported with the current loaded parameters." What do i do to get it to work so i can dial in my idle?
LS1TECH Sponsor
There should be some histos & PID info on our forum http://www.hptuners.com/forum/ the pids themselves in that some people like to simply plot their STIT's while others use STIT+LTIT and plot that, to create the histogram you just need to go into the configure histograms window, choose an open histogram & select the PID you want to plot ie STIT then for the axis simply choose the idle airflow table & it will attempt to plot it against that so long as you are logging the necessary parameters. There should be some histo's premade in our histogram repository though.
