launch noise?
Old 06-02-2008, 12:28 AM
oliphant14's Avatar
Default launch noise?
hey guys dont really know how to desribe this but basically there is a loud pop when ever i launch my car from a dig or even when i shift hard into a gear mainly the lower 3 gears srry bout the bad explination but help would be awsome thanks
Old 06-02-2008, 12:37 AM
oliphant14's Avatar
it also feels like it slips a little
Old 06-02-2008, 05:58 AM
Manic Mechanic's Avatar
Auto or standard? Sounds like a worn tranny or torque arm mount. Slide under the car and see if the rubber in the torque arm mount againt the tranny is pushed out or missing, if it looks good and won't wiggle up and down put a jack under the trans and see if light pressure will raise it apart at the transmission to crossmember mount.
Vernon
Old 06-02-2008, 07:23 AM
oliphant14's Avatar
its a manual i do have an aftermarket clutch with about 10000 miles on it but i have stock flywheel and slavecylinder could this be a cause also
Quick Reply: launch noise?
