What Shock for Stock Spring??
I got a ws6, would be nice to have a more planted feel.....
Besides the adjustable Konis, what would match the stock spring rate and give a more stable ride??? What is the final ride quality?? I got the hose mod out back.
As always, cost is an issue.
LS1TECH Sponsor
I wouldn't put QA1's on my worst enemies car.... well, on second thought maybe I would.
At this point you have horrible stock shocks. Most anything will be better because of what you starting with. I'd recommend either a set of Tokico non-adjsutables @ $345 a set as a good and decentely valving (if not great) set. They would have been appropriate as stock shocks, nothing more but nothing less.
Or, you can get a set of KYB AGX's for $409 a set. These offer you adjustment so you can play around with the ride/response and feel of the car to make it suit what you want. They are built better than QA1's IMHO, and have silly details that make them better like..... a gas charge to help keep shock fade away.
Koni's are the best. Great control without an overly stiff ride. The AGX's tend to ride a bit more stiffly at a similar amount of damping control, and have more coarse adjustments. For me it'll always be Koni over AGX's, and AGX's always over QA1's.... MHO
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
All hail, the sensei has entered!!
Thx for the tip!
Oh, and what about high-speed driving?? Damping over potholes?? "Planted" feel?? Would the non-adjustable Tokico or AGX assist in these areas??
--dan
Thx for the tip!
--dan
LS1TECH Sponsor
Both would... but the Tokico's offer you no ability to change damping levels to suit. That "planted" feel is good rebound control, and it is what it is in a non-adjustable shock. Where as when you can change the level of force, you change the way the car takes a set. The issue with AGX's is that any change in rebound is accompanied by a change in compression damping as well and that hurts the ride more than with a Koni that only give you what we seek, a change in rebound and not in both.
__________________
LS1TECH Sponsor
I think it's pretty clear in post #3..... And the warranty sucks on both when you try to cash it in. Koni excels here, the others give you exactly what you paid for in terms of service.
__________________
