SLP line lock craped out... help
Old 06-02-2008, 02:53 PM
BlackSS2001's Avatar
Default SLP line lock craped out... help
Well it stoped working on me.. I can hear it clicking so it's getting power but it wont hold the pressure. It kind of does but not near what it needs to/use to.
Do I need to rebuild it or what?
Old 06-02-2008, 10:20 PM
*98TransAm*'s Avatar
how long have you had it on the car? i know with my linelock after i activate it i pump the break pedal a few times to build up pressure then it holds fine.
Old 06-02-2008, 11:36 PM
I've had it over a year I think. I've never had to pump the pedal.
Old 06-02-2008, 11:52 PM
waterbug1999's Avatar
Ive had my SLP LL for over 2 years now with no issues..... Do you think bleeding the brakes could help?
Old 06-03-2008, 11:46 AM
it might.. but i really don't see how it would unless I had a leak..
Old 06-03-2008, 07:20 PM
yeah double check all the fittings and try bleeding the breaks. o and make sure the master cylinder is full
Old 06-03-2008, 09:44 PM
The master cylinder is full. I did a burnout today just using the foot brake to see if my front brakes would hold and they did but the car kicked to the left (driver side) really hard. My car has never kicked sideways this hard.
Old 06-04-2008, 12:50 PM
2000Z28ls1's Avatar
when I first installed my Slp Line lock, I didnt tighten the fiting down tight enough and it did the same thing, look around it when you are messing with it to check for any brake fluid sounds like a leak to me. but im no expert
Old 06-04-2008, 12:54 PM
Revelation Z28's Avatar
try activating it in the garage with a friend looking at the lines and solenoid. sounds like the solenoid isnt pushing fluid.
Old 06-17-2008, 11:28 AM
still not working no leaks. It's clicking so I know it has power, and it doesn't "unclick" untill I let off the button.. pumping the pedal doesn't help any either.
