Got a little wheel hop!!
Old 06-02-2008, 10:05 PM
boola1341's Avatar
Default Got a little wheel hop!!
Noticed a little wheel hop in the burnout box at the track. Spooked the **** out of me at first. Didn't even get to smoke the tires. With that said I think I need some lower control arms. What else......shocks? Car still has stock suspension. Not planning on lowering it unless that will help stop the wheel hop. Car is a daily driver with 90k miles on it.
Old 06-02-2008, 10:42 PM
Breathtaker's Avatar
Relocation brackets and lca's.
Old 06-03-2008, 12:21 AM
hpjunky98's Avatar
That should fix your wheelhop, but you should take your own advice in you original post and look into shocks down the road.
Old 06-03-2008, 09:15 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Boola, if your car has stock suspension, lca's and relocation brackets make a huge difference in the way your car performs. We offer two different versions of the brackets, a bolt on version CAB002 for the stock rearend or the weld on ones CAB001 for aftermarket like moser or strange. You can use the weld ons on a stock rear as well. We offer several different types of lower control arms. Here is a link to our suspension page and driveline page. If you have any questions please give us a call.
http://www.bmrfabrication.com/F-bodySuspension.htm
http://www.bmrfabrication.com/F-bodyDrivetrain.htm
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 06-03-2008, 10:49 AM
Empatho's Avatar
get relocation brackets and lca's
Old 06-03-2008, 01:46 PM
94'BLKBRD's Avatar
Old 06-03-2008, 02:37 PM
defenestrate's Avatar
i just put relocation brackets on my car (bolt in) and it completely eliminated the wheel hop. car plants much harder, you can feel the difference-and this is with stock lca's. i would suggest going with just the brackets right now, being that they are cheaper, and if you still need the lca's you can always order them.
Old 06-03-2008, 03:18 PM
UMI Performance's Avatar
Boola, Yes as mentioned a set of control arm relocation brackets and control arms will make a huge difference.
We carry the relocation brackets in both bolt in and weld in versions and have control arm kits as low as $109.99 a set. I posted a few links below, if you have any questions please ask and I will be glad to help.
www.umiperformance.com/2010
www.umiperformance.com/2012
www.umiperformance.com/2015
Thank you!
Ryan
Quick Reply: Got a little wheel hop!!
