I need diagnostic help
Old 08-12-2003, 02:53 PM
SPS_WS6's Avatar
Default I need diagnostic help
I have a 2000 TA WS6. My check engine lamp is on. I have two codes P0171(fuel trim system lean,bank 1) and
P0174(fuel trim system lean,bank 2). I have a tech2 scan tool,but don't see anything wrong with sensor values(that I know of). Anybody a tech out there that knows what's going on that can help me. Thanks alot.........
Old 08-13-2003, 06:18 PM
slow's Avatar
Default Re: I need diagnostic help
any chance you ported you maf?
Ryan.
Old 08-15-2003, 12:02 PM
SPS_WS6's Avatar
No I haven't. I've seen what seems like a lot of people talking about defective MAFs and these codes but it seems to me it should be further down the line, like an O2 sensor or something......
Old 08-15-2003, 12:20 PM
slow's Avatar
since both are showing lean conditions, i find it hard to believe they bolh died at the same time.
Something that effects what goes into the motor, would be more likely to give a low output for both sides.
low fuel pressure, clogged filter, or dying pump could cause this problem. There are a few other things too, but im not sure off the top of my head.
Just my $.02.
Ryan.
