John_D.
06-03-2008, 04:41 PM
Is that something I can fix myself?
The turbo was rebuilt, and has less than 200 miles on the rebuild. I'd rather not have to send it off because it took nearly 3 months the last time, and especially if it's a 99 cent part I'd rather do it myself...
I pulled the turbo off the car today and let it hang by a wire. (it's a rear mount) Just the center section. Kept the pressurized feed hooked up, let the return just gravity drain into a pan with no hose on it, just the fitting. (no pump, no line, just gravity from a turbo hanging in the air)
It's dumping out the exhaust side, but the cold side didn't show any signs of leaking.
I turned the muffler upside down in a bucket and got about 1/3 quart of oil out of it... So it's been doing it consistently.
It's always spewed some out the back (just a little, looking at the bumper) but it's really pouring now. Cloud of smoke when getting on it, and dripping out of the tailpipe. (no smoke when I took it for a test drive just now with no turbo on it)
When it took the big turn for the worse, is after I let it sit in the driveway idling to warm up for about 5 minutes, not realizing that the ground for the oil pump (and buzzer) was not hooked up. After that the leaking went from barely noticeable, to the back of the car is covered up.
I do have a restrictor in it, and I can hold my thumb over the return fitting and hold back the flow without much pressure building up at all.
Thoughts? Tips?
(how to disassemble, where to find a seal, any issues with balancing, etc.)
This is the 67 (upgrade) that ships with the STS kit.
Thoughts? Tips?
