Damn T/A power antenna! help
Old 06-03-2008, 06:45 PM
Johawk's Avatar
Default Damn T/A power antenna! help
I started my car today and for some reason was too lazy to take the car cover all the way off and left it on the back half of the car. So the radio was on, the antenna went up and broke. now its stuck about 3/4s up and if I pull it up by hand it falls back down, and it wont go back down. Do I need a new mast, motor, or is this just something stupid that can be fixed. I didnt have much time to look at it yet. I did it before I had to leave for work and thats where I am now. Thanks for any help
Old 06-03-2008, 08:21 PM
my bandit's Avatar
if you dont really listen to your radio that much just push it down and disconnect the power to it. idk what the reception would be like with it down.
Old 06-03-2008, 08:28 PM
Johawk's Avatar
hahaha I thought of that but I would rather fix it. I wish it would only go on with the radio.... and not with the CD player. Then I wouldnt have had this problem. lol
Old 06-03-2008, 08:36 PM
my bandit's Avatar
i just like the look of it down. imo it looks cleaner.
ive heard of people buying new ones at advance for about 30
Old 06-03-2008, 08:40 PM
Johawk's Avatar
I agree... If I wanted to repaint my quarter panel I would shave it. My GTP had the antenna in the rear glass and was nice and sleek once I removed that stupid onstar antenna
Old 06-04-2008, 08:27 AM
Save the manuals!
wssix99's Avatar
You definitely shouldn't go through life with a limp rod - you can a new mast from a dealer or Delco parts supplier, #10256439. The new mast comes with installation instructions.
Old 06-05-2008, 09:36 AM
Johawk's Avatar
I took it all apart and that stupid plastic cogged belt that pushes the antenna up and down was cut short inside the motor... I hope when I install the new one the piece from the old one doesent screw up the motor. I was unsuccessful at retrieving it.
Old 06-06-2008, 08:10 AM
Save the manuals!
wssix99's Avatar
The old belt bends and forms a tight circle inside the motor casing, which is why it won't come out. Its probably still wrapped around the gear inside the mechanism. If you try putting the new mast in and the old belt is still inside, there may not be enough room for the new belt, which could damage it as well.
I've never done it, but maybe there is a way to get in there to service the unit and get the old belt out?
Old 06-06-2008, 08:22 AM
Johawk's Avatar
The whole thing is held together by melted plastic rivits. The motor still runs and you would think it would push the old piece out... but it didnt. I'll have to take another look at it and see if it can be opened up without destroying the unit
Old 06-06-2008, 01:35 PM
Save the manuals!
wssix99's Avatar
I just threw one of my old masts out, otherwise I'd send you a picture. As the belt ages, it gets stiff and has some memory to it that keeps it coiled up. (When you take the belt out, it goes back in to the coiled position.) If you have a broken piece around the gear, its probably coiled up, which is keeping it from coming out the straight tube away from the gear. (It would just keep going around and around in circles.)
Old 06-07-2008, 01:49 AM
Jassick's Avatar
Reception-terrible.
had mine break, snapped near the bottom, so i just cut off the cable, now it stays down.
time to up your cd collection!
Old 06-07-2008, 06:51 PM
my bandit's Avatar
Originally Posted by Jassick
Reception-terrible.
i guess it all depends on how strong the signal is then b/c my friends was the same way and he doesnt notice a difference
Old 06-07-2008, 07:55 PM
1sick'98WS6's Avatar
I bough a whole new assembly that just plugs right into where your old one did, Its delco so its factory. Some partslady on ebay sells them..
