Suspension & Brakes - Koni shocks with stock springs ('00 Z28)
vtirocz
06-03-2008, 07:56 PM
I've decided I'm going to get Koni shocks (4th gen) and keep my stock springs on my '00 Z28. I just did the 1LE front swaybar and it feels much better now, even on stock shocks.
My question is this... Is 4 sweeps from full hard in the front, and 1/2 turn from full soft in the rear the best starting point? I want a ride that's not too harsh on rough roads, but still handles good.
What's everyone else running and how do you like it?
Thanks.
z28bryan
06-03-2008, 10:37 PM
I would start at full soft in the rear first. That's what I run currently on my Strano springs as well.
Killer_Bluebird
06-04-2008, 01:14 AM
Full soft in the back and maybe back up another sweep softer in the front (5 from full stiff). That should give you a good starting point with stock springs as you don't need as much damping as you would with a stiffer spring.
vtirocz
06-04-2008, 09:24 PM
Thanks for the input. I will try 5 sweeps from full hard in front and full soft in the rear.
Any other opinions on this?
