Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
502rwhp M6 Needs Traction/tire Advise!
Old 06-03-2008, 08:10 PM
TwoSS'sinNY's Avatar
Default 502rwhp M6 Needs Traction/tire Advise!
I'm running stock shocks, V6 springs in the back and the front sway bar is disconnected. I'm on 315/35/17 Nitto 555R's now...their good for the street but I'm thinkin about a 15" rim and a wrinkle wall tire for the track. I want to be able to launch @5000rpm
Old 06-03-2008, 09:54 PM
Also I have a strange 12 bolt rear w/4.11 gears and nitrous ready DS. I launch at 3000-3500 rpm now! I'm spinning through 1st and into 2nd
Old 06-03-2008, 09:58 PM
josh2002-ws6's Avatar
Are you all motor, forced induction, or nitrous? I would go with lower control arms, a torque arm, and adjustable shocks all the way around to start off.
Old 06-03-2008, 10:08 PM
Yes, I'm all motor, and have lower control arms, sfc's and a torque arm.
Old 06-03-2008, 10:26 PM
jason02Z's Avatar
try 275/60/15 et street radial or the 275/50
Old 06-04-2008, 07:52 AM
will I get beter hook on that than the new 315/35/17 Hoosiers or the 315/35/17 ET Street Radials? I want what ever will work the BEST it sucks when you cant get traction.
Old 06-04-2008, 08:26 AM
bad2000z's Avatar
I pulled a couple 1.49's at Skyview last Friday night with my 275/60/15 M/T DR's. E.T. Drags might work a little better with an M6 car though. We need to get that car to a better track, maybe NYIRP. Traction is a lot better up there.
Old 06-04-2008, 09:17 AM
BigKap94z's Avatar
I didn't have much luck with the 17" DR's. 255/50/16 MT DR's were at minimum a tenth better. I was able to do 1.6 60fts easy on the 255's. When are u going to the track next? I have a set of wheels with these DR's on them, but only a little tread left if u want to give them a try. Launching on DR's with a stick can be a bit trickky, maybe ill see u up there and try to watch u and give some pointers. Shoot me a PM if u want to try my MT DR's.
Old 06-04-2008, 10:05 AM
jason02Z's Avatar
17's will never work as was as u want with a 6spd,4.11's and 500hp. they might feel alright on the street but at the track not so good.. i just got some 275/50/15 running bout the same power but through an auto and stock gear. they hook a 100% better than the 17's dr's i had...at 40+mph. if u dont mind a tall tire get the 275/60/15 28" tall better for 4.11 and m6
Old 06-04-2008, 10:16 AM
Frans96SS's Avatar
if you wanna keep your wheels then yes get a 315 et street radial... i LOVE the et street radials... you should be able to get a decent 60 on them.
Old 06-04-2008, 07:20 PM
cdubbzz's Avatar
17" drag radial can work if he's willing to use a true 28" tire
M&H's 325/45/17 (rollout is 88")
If he's willing to try a different rim then I'd say def go 15"
And something like 12 way QA1's are a must!!!
Old 06-04-2008, 09:03 PM
I'm willing to try a different rim, because my car is geared for a 26-27 inch tire. Can you tell me what backspacing I would need, or what rim to use? Probably a 27x11.5x15 Hoosier QTP
Old 06-04-2008, 09:35 PM
cdubbzz's Avatar
many guys run 15x10 rim w/ 7.5" bs
you may want to search in wheels/tires section for
more info
Old 06-04-2008, 11:26 PM
jason02Z's Avatar
15x10 and a lot of grinding..i just did all that last month. but if ur not into all that grinding or want the 15's u can get the 325/17/45 like cdubbzz said. i was thinking of doing that being a lil cheaper that a set of 15's..
Old 06-05-2008, 04:58 AM
Race your car!
JL ws-6's Avatar
listen, you can try the radial, but if you wantsolid preditable consistant traction regardless of track prep, get yourself the 15 inch wheels, and a set of full slicks. I don't think you're making enough power to really need a 28 inch tire, but a set of 26x10.5 ET drags would do wonders for the traction department.
That has a way better chance IMO of holding then the radial does, the radial will work if your suspension is really well set up, but for a starting point, I would do a bias ply tire. You put them on, and it will pretty much work, put a radial on, it might work.
Sidewall is your friend, the 15 inch rim, wether you do a radial or a bias ply will make all the difference.
You don't have to spend the big $ on bogarts, convo pro's will clear on the front and the 8 inch wide ones will clear on the rear with no grinding. Not the ideal rear rim width, but it's miles better then messing with 17inch tires on a drag car.
Old 06-05-2008, 07:37 AM
CamaroRacing12's Avatar
^^^^^ what he said!
Old 06-05-2008, 09:00 AM
bad2000z's Avatar
Well said JL. I'm running 15x10 Draglites with 7.5 backspace. It took a lot of grinding to make them fit, and I ended up running 7/32 spacers too.
Old 06-05-2008, 09:04 AM
Race your car!
JL ws-6's Avatar
I know the 15x8 convo doesn't need any grinding, chef has a set and they went right on his car no grinding at all.
The fronts do the same they go right on with no modding at all.
The 15x10 is a better size because it spreads the tire out and increases the footprint, and helps decrease the tire groth a little, but it's either grind the **** out of the calipers which I personally don't think is the safest thing, spend a good bit more $ on bogarts, or go to drag brakes in the rear and eliminate the abs/tcs.
Old 06-05-2008, 08:04 PM
CARTEK Racing
WS6TransAm01's Avatar
I would use the M/T ET Drag 10.5 x 26 15, and look into the stiff sidewall as you are a stick car.
I used those tires when I had 4.10's in the car and I loved them.
Old 06-06-2008, 08:13 AM
bad2000z's Avatar
I have a pair of Hoosier 26x10 slicks in decent shape if you want to try them $100.
Quick Reply: 502rwhp M6 Needs Traction/tire Advise!
