High oil pressure after cam swap?!
Old 06-03-2008, 08:50 PM
Blackboosted2's Avatar
Default High oil pressure after cam swap?!
I just fired my car for the first time, it runs great....but my oil pressure has been showing 105-125lbs!!
I think it's just a faulty sensor though. The thing that makes me think it's the sensor is the fact it shows 60lbs when the engine is OFF (but drops to 0 when the key is pulled) I plugged in HP Tuners and it shows the same
What does this typically mean? I may have hit the sensor while tearing out all the AIR stuff behind the intake manifold....so the sensor may just be bad?? I put in a new LS6 oil pump during the cam swap. And changed the oil with a new filter. I ran the car for 20min since I felt brave and it seemed fine
oh and video
http://www.indyhpmedia.com/index.php...BlackBoosted2/
The video called Blackboosted2 Vette untuned idle.avi
Old 06-04-2008, 07:18 AM
still looking for ideas
Old 06-04-2008, 07:44 AM
s346k's Avatar
it's the sensor. my buddy had a c5 that did the exact same thing...but his did it for no reason, the car was a rock stock 98 a4.
Old 06-04-2008, 08:21 AM
LS1Tech Sponsor
Dennis@SpectacleSolutions's Avatar
its the sensor. common problem.
Old 06-04-2008, 03:18 PM
Thanks guys, I will get one ordered
Old 06-04-2008, 03:21 PM
bjamick's Avatar
How did you see your oil pressure on HPtuners? I've got it but it doesn't show it on the guage screen in the scanner.
Old 06-04-2008, 08:52 PM
wht01ws6ta's Avatar
+1 Where do you see oil pressure on HP Tuners? Mine always reads high on the gauge after I snapped off and then replaced the sensor doing an intake swap
Old 06-04-2008, 10:43 PM
You have to re-configure your "gauges" that are viewable, it's in the settings within HP Tuners
It was reading the same as the gauge in my dash, and the digital readout in the Vette's dash
Old 06-12-2008, 12:30 PM
bjamick's Avatar
Ya bc all my guages are jacked when I removed my guage cluster for LED's
Old 06-13-2008, 09:53 AM
RaceDriver's Avatar
He has a Vette... I believe the Vette PCM monitors oil pressure, while the F-Body unfortunately does not.
Quick Reply: High oil pressure after cam swap?!
