18" C6 Z06 with 295-35
Old 06-04-2008, 07:30 PM
blades11b's Avatar
Default 18" C6 Z06 with 295-35
Hey well i finally got my C6 Z06's in with the Vredestein 295's for the rear i also am going to be putting on a set of Strano's springs which should drop it between 1.25" and 1.5" does anyone know if ill have any rubbing issues? i know someone out there has this setup so please help
Old 06-04-2008, 07:42 PM
cookba's Avatar
i have 275/40/18 KDW on the rear of my car with Koni 4/4 and Strano springs. i think for safety of your tires i would roll the fenders. with a 295 you might have to do the BFH mod, what is the sectional width of the tires?
Old 06-05-2008, 08:43 AM
Colin91Z's Avatar
I've got 295/35 Bfg drag radials mounted on 18x10.5 C5 Zo6 wheels on the rear of my car, and it's lowered with Eibach Sportlines (approx 2" drop)
I had to do the BFH mod to the front of the inner fenders, and remove my bump stops. Now they fit great with no rubbing.
Old 06-06-2008, 06:22 PM
blades11b's Avatar
well damn i was hoping to not have to BFH it so we will see what happens
Old 06-07-2008, 09:21 AM
Colin91Z's Avatar
Well every car is a little different....If it gives you any hope, we test fitted my rear wheels on a friend's 01 SS with strano springs, and they cleared almost perfectly....but under slightly hard cornering they would still run a little bit on his inner fenders, so a little BFH mod would still be necessary on his car if he wanted to run them, although not near as much clearancing as my 96 required.
